Project Vinyl Cleaner VC-S (SOLD)
Selling preloved Pro-Ject vinyl cleaner model VC-S, with original acrylic cover(bought seperately, as this is optional accessories) SOLD
https://wa.me/60122738893
Extremely capable wet cleaning machine that removes dirt and dust from your valuable records
VC-S is a radical new development. There are features which are new for record cleaning machines in this pricerange:
It is super powerful and cleans a record in 1 max 2 rotations (best is 1 turn forward, 1 turn backward)
It turns the record superfast within 2 seconds per rotation, which is about 3 times faster than usual cleaning machines do. The result is a much faster cleaning of records as well as much cleaner and 100% dry records with NO residual humidity!
A new type of clamp seales the record label from cleaning fluid and avoids damage on the label!
Robust metal arm, which is easy to use, mechanically stable fixing! (no springs)
Big container (2,5 l) for used fluid, that shows fill-up capacity and guarantees no spillage of used cleaning fluid. Discharging of used fluid is extremely easy to do.
Newly developed vinyl cleaning concentrate Wash it offers very good cleaning results and reduces static charge, so record wear as well as stylus wear is signaficantly reduced.
tongho- Frequent Contributor
- Number of posts : 879
Amplification: Accuphase E470
Speakers: Quad z3
» Ultrasonic vinyl cleaner sold
» vinyl record ultrasonic cleaner-sold
» Vinyl Record Cleaner (used)
» Ultrasonic vinyl record cleaner.
» Amari Rw-200 Vinyl Record Cleaner (used)
