Thiel Audio CS1.6 Loudspeakers
Item: Thiel Audio CS1.6 Loudspeakers
Condition: Item is in very good working condition. No dents or scratches. Comes with original grills and spikes.
Price:RM4500 RM4300 or swap/topup
Description: Two-way, magnetically shielded, floorstanding loudspeaker. Drive-units: 1" (25mm) aluminum-dome tweeter, 6.5" (165mm) metal-cone woofer with 3" voice-coil. Crossover frequency: 3kHz. Crossover slopes: first-order, 6dB/octave. Frequency response: 50Hz-20kHz, ±2dB. Phase response: ±10 degrees maximum. Sensitivity: 90dB/W/m. Nominal impedance: 4 ohms, 3 ohms minimum. Recommended Power: 50-300W.
Dimensions: 35.5" (902mm) H by 9" (229mm) W by 11.5" (292mm) D. Weight: 38 lbs (17.3kg) each.
Finishes: Painted black; wood veneers available at extra cost.
Serial numbers of units reviewed: 459, 460.
Price: $1990/pair in black; $2390/pair in wood veneers.
https://hometheaterreview.com/thiel-cs16-floor-standing-loudspeaker-reviewed/
https://www.stereophile.com/floorloudspeakers/663/index.html
https://www.stereophile.com/content/thiel-cs16-loudspeaker-specifications
http://www.soundstagenetwork.com/revequip/thiel_cs16.htm
https://www.hifinews.com/content/thiel-cs16-%C2%A31995
Price:
» Thiel Audio CS1.6 Loudspeakers
» Thiel CS 1.5 Loudspeakers (used)(SOLD)
» Thiel CS 7 Loudspeakers (Used) SOLD
» Thiel CS7 Floor Standing Loudspeakers
» BOENICKE Audio W8 Loudspeakers (Sold)
