Thiel Audio CS1.6 Loudspeakers
Thiel Audio CS1.6 Loudspeakers Empty Thiel Audio CS1.6 Loudspeakers
Post by raymond88 Thu Jun 02, 2022 1:54 pm
Item: Thiel Audio CS1.6 Loudspeakers
Condition: Item is in very good working condition. No dents or scratches. Comes with original grills and spikes.
Price: RM4500 RM3900 or swap/topup
Thiel Audio CS1.6 Loudspeakers Thielc12
Thiel Audio CS1.6 Loudspeakers Thielc11
Thiel Audio CS1.6 Loudspeakers Thielc13
Thiel Audio CS1.6 Loudspeakers Thielc14
Thiel Audio CS1.6 Loudspeakers Thielc15
Thiel Audio CS1.6 Loudspeakers Thielc16
Description: Two-way, magnetically shielded, floorstanding loudspeaker. Drive-units: 1" (25mm) aluminum-dome tweeter, 6.5" (165mm) metal-cone woofer with 3" voice-coil. Crossover frequency: 3kHz. Crossover slopes: first-order, 6dB/octave. Frequency response: 50Hz-20kHz, ±2dB. Phase response: ±10 degrees maximum. Sensitivity: 90dB/W/m. Nominal impedance: 4 ohms, 3 ohms minimum. Recommended Power: 50-300W.
Dimensions: 35.5" (902mm) H by 9" (229mm) W by 11.5" (292mm) D. Weight: 38 lbs (17.3kg) each.
Finishes: Painted black; wood veneers available at extra cost.
Serial numbers of units reviewed: 459, 460.
Price: $1990/pair in black; $2390/pair in wood veneers.
https://hometheaterreview.com/thiel-cs16-floor-standing-loudspeaker-reviewed/
https://www.stereophile.com/floorloudspeakers/663/index.html
https://www.stereophile.com/content/thiel-cs16-loudspeaker-specifications
http://www.soundstagenetwork.com/revequip/thiel_cs16.htm
https://www.hifinews.com/content/thiel-cs16-%C2%A31995
Number of posts : 10077
Thiel Audio CS1.6 Loudspeakers Empty Re: Thiel Audio CS1.6 Loudspeakers
Post by raymond88 Fri Jun 10, 2022 12:56 pm
Post by raymond88 Fri Jun 17, 2022 3:04 pm
Post by raymond88 Fri Jun 24, 2022 2:40 pm
