Klipsch SPL-120 12" Powered Subwoofer
Ok View demo test cod KL
Brand new condition
Display unit
The SPL-120 subwoofer is a step up from the Klipsch Reference series. Featuring a high-efficiency Class-D amplifier and spun copper Cerametallic:tm: woofer, the Klipsch SPL series subwoofers deliver best-in-class low frequency output.
Features:
12" Spun Copper Cerametallic:tm: Woofers
Bass-Reflex via Exclusive Front-Firing Internal Flare Port
Class D Amplifier with 300W RMS / 600W Peak
Premium Scratch-Resistant Finish
Strong, Flexible Removable Magnetic Grille
Dimensions: 17.75” x 14.7” x 19.9”
HIGH EFFICIENCY CLASS D AMPLIFIER
The built-in, high efficiency amplifier features an analog preamp design, which maintains the original signal path for cleaner, true-to-source reproduction. The Class D output stage ensures maximum efficiency for maximum output, detail, and low frequency power.
SPUN COPPER CERAMETALLIC WOOFERS
Cerametallic:tm: woofers are exceptionally light and extremely rigid, providing remarkable low frequency response with minimal cone breakup and distortion for higher, cleaner output using less amplifier power.
WOOFER ANATOMY
Klipsch Cerametallic:tm: cones are matted to a dual-layer, copper-wound voice coil for exceptional conductivity.
Reference Premiere woofers are housed in a non-resonating, stamped-steel basket that’s secured to a large magnet motor for exceptional efficiency and low distortion, and matched to our horn-loaded tweeters for optimal acoustic execution.
EXCLUSIVE PORT TECHNOLOGY
Klipsch SPL subwoofers leverages proprietary internal-flare geometry that minimizes port noise for clean undistorted low frequencies. The front-firing design allows for placement flexibility to reduce unwanted resonance from your walls or furniture behind the subwoofer.
TAKE CONTROL
Low Pass Crossover and Variable Phase control allows you to tune the subwoofer to your Klipsch speakers and to your room, establishing the ideal level of bass. Line Level / LFE RCA inputs ensure compatibility with home theater receivers.
Both the RCA and wireless inputs can be utilized, giving you the ability to use a single subwoofer with multiple system in the same room. For example, you can use the wireless input for your home theater set up and the RCA input for your 2-channel system, without needing to switch inputs when changing between systems.
ULTRA-DURABLE DESIGN
Klispsch SPL subwoofers feature a scratch resistant ebony finish that looks like real wood and covers the entire cabinet. Shock-absorbing rubber feet, steel grille posts and a woven cloth grille give the SPL subwoofers a premium look and feel
Used less then 200 hours
Specification last picture
www.wasap.my/60143413655
RM2290
- Number of posts : 2913
rkky likes this post
» Klipsch SPL-120 12" Powered Subwoofer
» Klipsch KSW-50 powered subwoofer (sold)
» Klipsch SW-10I Powered Subwoofer (SOLD)
» Klipsch SW-115 Powered Subwoofer (used) SOLD
» Klipsch R-100SW 10" Powered Subwoofer
