Marantz MA500 Mono Block Power Amplifier - 4 pcs available
Marantz MA500 Mono Block Power Amplifier - 4 pcs available Empty Marantz MA500 Mono Block Power Amplifier - 4 pcs available
Post by raymond88 Fri Jul 01, 2022 11:31 am
Item: Marantz MA500 Mono Block Power Amplifier - 4 pcs available
Condition: 8/10. Item is in excellent condition. No dents or scratches. Comes with attached power cable with UK plugs.
Price: RM950 RM850 per piece
Have 4 pcs available
Can Trade-In your Amplifier/
Marantz MA500 Mono Block Power Amplifier - 4 pcs available Marant49
Marantz MA500 Mono Block Power Amplifier - 4 pcs available Marant50
Marantz MA500 Mono Block Power Amplifier - 4 pcs available Marant51
Marantz MA500 Mono Block Power Amplifier - 4 pcs available Marant52
Description:
Product Information
Treat your family and guests to quality entertainment by using the Marantz
MA-500 1 Channel Power Mono Amplifier. This unit is compact enough to be
functional and stylish in practically any spot in a room. Able to deliver 125
watts into 8 ohms, this product is ideal for powering just about any speaker.
In fact, it can create a new multi-channel home theater or provide an
additional channel for amplifiers to an existing system. An RC-5 remote
control also makes it possible for users to change settings without getting up
from the comfort of their seats. This black amp weighs a mere 13.2 pounds,
which makes it possible for users to move it easily from one spot to another.
They measure 19 inches in depth by 3.5 inches in width by 6 inches in
height.This Monoblock equipment is specifically designed for use in home
theaters and surround-sound system setups. The 125-watt and 180-watt
performance delivers high power into 8-ohm loads, ensuring that users don't
lose signals even in challenging audio environments. A frequency response
between 10 and 100K combines with a signal-to-noise ratio of less than 116
decibels, making it a practical choice for beginners who want a high-tech
music solution that can easily synchronize with a variety of music systems and
accessories. The product can be bridged at 8 ohms for a total of 360
watts.This isn’t just a reliable product for home theater and small
professional setups. The amp also boasts an excellent reputation for its
support for home computers, car subwoofers, speakers, and other accessories.
In fact, these amps will never run out of breath. Marantz MA-500 1 Channel
Power Amplifier can really provide a lot of RMS power. Buyers should not rule
out flexible integration of these capable products because they can offer a
pleasing experience when properly paired and tuned.This product delivers the
kind of performance enthusiasts expect from the highest-end amp. It has plenty
of reserve energy even when hooked up with some of the most modern speakers
and receivers. As for performance, the sound quality will endure even at lows
as low as 20 hertz. In addition, it will continue to show clear and precise
mids and highs almost every time. Even non-audiophiles are likely to be
impressed by the clear sound and amazing bass response. This is the kind of
performance that’s sure to keep you on your toes. That’s particularly true
when hooked up to phono preamplifier or even ma-9s2 block amps, receivers,
advance stereo headphones, and other monoblock gear.Overall, the durability
and audio quality of MA500 is sure to serve you well now, and even as audio
technology advances. This is a great choice for casual listeners, audiophiles,
and even professionals who want reliable equipment, small size, and high
output. This is a sublime amplifier design that should satisfy even the most
demanding listener.
Product Identifiers
Brand Marantz
MPN MA500
Model MA-500
Number of posts : 10090
Marantz MA500 Mono Block Power Amplifier - 4 pcs available Empty Re: Marantz MA500 Mono Block Power Amplifier - 4 pcs available
Post by raymond88 Fri Jul 08, 2022 4:26 pm
Post by raymond88 Fri Jul 15, 2022 10:11 am
Post by raymond88 Fri Jul 22, 2022 9:50 am
Post by raymond88 Fri Jul 29, 2022 12:35 pm
