Pro-Ject Audio Systems Stereo Box DS (Made In Europe) (Used)
The high-performance integrated amplifier features dual-mono amplification topology using the highest quality PWM amplifier modules (two per channel) for audiophile-grade sound. This amplifier is not only powerful but, is capable of driving difficult speaker loads and is stable down into 2 ohm operation. In addition to four pairs of RCA line level jacks to accommodate a selection of analog inputs, a USB digital input provides easy direct interface with computers.
The built-in D/A converter provides superb sound from your computer files and simplifiesinterface and operation. The large and legible display readout provides status of every operational mode and can be read across the room. The massive metal case shields the internal circuitry form not only detrimental vibrations but also electromagnetic interference. Additionally, the outboard power supply also contributes to the low-noise environment. An IR remote control is supplied.
Specification
Output Power 2 x 40W / 60W at 8 ohms / 4 ohms (both channels driven)
Frequency Response 10Hz – 50kHz (+0dB/-3dB)
Channel Separation > 40dB @ 20kHz
Signal to Noise Ratio > -90dB (IEC -A)
Power Consumption 5A DC, <1W standby
Outboard Power Supply 24V/5A DC
Speaker Connectors 4mm Banana Jacks, Spade Connectors or Bare Wire
Sampling Rates 44.1kHz and 48kHz
Conditions: 9/10 (USED)
Price: RM1690 inclusive postage to West Malaysia
- Number of posts : 5622
» Bower And Wilkins DM603 S2 (Made in europe) Hifi audio floorstand speaker
» Pro-Ject Audio Systems Record Puck Brass (USED)
» Denon DCD 755AR CD player (made in Europe)-new lens
» Pro-Ject Audio Systems Tube Box DS2 Phono Stages(SOLD)
» [SOLD] Pro-Ject Audio Systems Sweep It S2 Record Broom
