Keces E40 Integrated Amplifier / Preamp / DAC / Headphone Amp
Item: Keces E40 Integrated Amplifier / Preamp / DAC / Headphone Amp
Condition: 9/10. Item is in like-new condition. No dents or scratches. Comes with original remote and power cord. Few months old and very minimal usage.
Price: RM2100 or swap/topup
E40 has some huge ventilation holes underneath and on top of the unit, already telling a story about its working principles and power output. After feeling how hot it is after about two hours of work, I have already a premonition about its working topology, but more about that very soon.
I was also surprised by those metal feet underneath it padded with lots of rubber to absorb micro-vibrations, so everything is simply well made to very high standards and I am actually surprised by the price point KECES went with this unit.
It has the simplest control scheme you could possibly have. On the front panel you can spot an On/Off Button, a headphone jack, an input selector button, a motorized volume wheel on the far right and in the middle four low-intensity LEDs will show the selected input.
On the back, from left to right you have an MM phono input to connect it to a turntable, two analog inputs in case you’ll want to use as an integrated or as a headphone amp only, there is also a pre-amp output that can also work with a powered sub-woofer. There is a USB Type-B input that makes it work as a dedicated DAC with your PC or MAC, be warned though that you will be limited to 16-bit 48 kHz files only. On the right you have your speaker outputs, the AC inlet and an On/Off switch.
50 watts per channel @ 8 Ohm.
Asynchronous USB 2.0 supports PCM up to 48kHz/16-bit.
Phono input for MM with 47k ohm.
2 pairs RCA line level Analog inputs
Preamp output for adding a subwoofer
Favorite volume memory with remote control button.
Superb sounding headphone jack.
The 3mm thickness of the aluminum chassis to effective to blocks EMI/RFI interference.
The full-metal body realizes both vibration control and elegant style in an half-size body that enables placement on a desktop to be a PC HIFI system or to be a small stereo system.
Power Output
50W x2 @ 8ohm.
65W x2 @ 4ohm.
Power Bandwidth
5Hz – 100kHz.
Total Harmonic Distortion (THD+N)
<0.008% at 1kHz A-Weighting.
Total Harmonic Distortion (THD+N) for Phono MM
<0.02% at 1kHz A-Weighting.
S/N R
110dB A-Weighting.
S/N R for Phono MM
82dB A-Weighting.
Digital to Analog Converter
Supports PCM up to 48kHz/16-bit.
AC Input Voltage
110V-120V, 60Hz / 220V-240V, 50Hz (Switchable).
Power Consumption
180 Watts.
Casing
3mm Aluminum.
Dimension (WxDxH)
220x220x66mm.
Weight
4KG.
Power Output
50W x2 @ 8ohm.
65W x2 @ 4ohm.
Power Bandwidth
5Hz – 100kHz.
S/N R
110dB A-Weighting.
S/N R for Phono MM
82dB A-Weighting.
AC Input Voltage
Power Consumption
180 Watts.
Casing
3mm Aluminum.
Dimension (WxDxH)
220x220x66mm.
Weight
4KG.
» WTS: Linear Tube Audio MZ-2 Headphone/ Preamp/ Integrated Amp [SOLD]
» Melos SHA-1 Tube Preamp/ Headphone Amplifier
» Keces E40 Integrated Amp (Sold)
» Rudistor rp8 headphone amp/preamp
» audio-gd HE9 MK2 Headphone Amp & Preamp (SOLD)
