Audio Research Reference Phono Preamplifier(sold)
SPECIFICATIONS:
FREQUENCY RESPONSE: +- 15dB of RIAA,10Hz to 60kHz; 3dB points below 1.0Hz and above 250kHz
DISTORTION: .005% at 0.5v RMS 1kHz output
GAIN:selectable 48dB(LOW),69dB(High) at 1kHz(MC & MM compatible)
SWITCHES: Front(4) Power,Standby,Mono,Mute,Rear(1)Gain
INPUT IMPEDANCE: 47K ohms and 180pF Unbalanced (Low Gain),280 ohms Unbalanced (High Gain).(Provisions for any value below 47K ohms or added input capacitance for matching certain magnetic cartridges.)
OUTPUT IMPEDANCE: 200ohms Unbalanced.Recommended load 50K-100K ohms and 100pF.(10K ohms minimum and 2000pF maximum.)
MAXIMUM INPUTS: 100mV RMS at 1kHz (240 mV RMS at 10kHz).
RATED OUTPUTS:0.5V RMS 10Hz to 60kHz,100K ohm load(output capability is 30V RMS output at 1/2% THD at 1kHz).
POWER SUPPLIES:Electronically-regulated low and high voltage sipplies.Line regulation better than .01%
TUNE COMPLEMENT:(11) 6922/E88CC dual triodes,plus (1 each) 5AR4,6L6GC,6922 in power supply.
CONDITION:8/10
PRICE:sold
FOR MORE INFO, PLEASE CALL OR WHATAPPS:
016-5368723 YUAN
018-9742567 YANG
CONDITION:8/10
PRICE:sold
016-5368723 YUAN
018-9742567 YANG
YUAN- Frequent Contributor
- Number of posts : 135
» Audio research PH3 phono preamplifier (Used)SOLD
» Audio Research PH3 phono preamplifier (sold)
» Audio Research SP6A Preamplifier with Phono
» Audio Research SP14 Preamplifier with Tube Phono Input
» Audio research LS-22 preamplifier (Used)SOLD
