Audio Research PH3 phono preamplifier (sold)
FREQUENCY RESPONSE
±.15dB of RIAA, 10Hz to 60kHz. 3dB points below 0.5Hz and above 400kHz
DISTORTION (THD)
Less than .005% at .50V RMS 1kHz output
NOISE & HUM
0.1µV equivalent input noise, IHF weighted, shorted input (80 dB below 1mV 1kHz input)
GAIN
54dB at 1kHz (MC & MM compatible)
INPUT IMPEDANCE
47K ohms and 90pF Unbalanced. (Provisions for any value below 47K ohms or added input capacitance for matching certain magnetic cartridges.)
OUTPUT IMPEDANCE
200 ohms Unbalanced. Recommended load 50K-100K ohms and 100pF. (10K ohms minimum and 2000pF maximum.)
OUTPUT POLARITY
MAXIMUM INPUTS
60mV RMS at 1kHz (240 mV RMS at 10kHz)
RATED OUTPUTS
.50V RMS 10Hz to 60kHz, 100K ohm load (output capability is 30V RMS output at 1/2% THD at 1kHz).
POWER SUPPLIES
Electronically-regulated low and high voltage supplies. Line regulation better than .01%
TUBE COMPLEMENT
(3) 6922/E88CC dual triodes with JFET input. Solid state power supply.
POWER REQUIREMENTS
100-135VAC 60Hz (200-270VAC 50/60Hz) 28 watts maximum. Line fuse 0.6A SLO BLO (0.3A SLO BLO 230V)
CONDITION:8/10
PRICE: sold
FOR MORE INFO,PLEASE CALL OR WHATAPPS:
018-9742567 YANG
016-5368723 YUAN
DISTORTION (THD)
NOISE & HUM
GAIN
INPUT IMPEDANCE
OUTPUT IMPEDANCE
OUTPUT POLARITY
MAXIMUM INPUTS
RATED OUTPUTS
POWER SUPPLIES
TUBE COMPLEMENT
POWER REQUIREMENTS
CONDITION:8/10
PRICE: sold
018-9742567 YANG
016-5368723 YUAN
YUAN- Frequent Contributor
- Number of posts : 135
» Audio research PH3 phono preamplifier (Used)SOLD
» Audio Research Reference Phono Preamplifier(sold)
» Audio Research SP6A Preamplifier with Phono
» Audio Research SP14 Preamplifier with Tube Phono Input
» Audio Research LS7 Preamplifier (SOLD)
