AudioQuest SUB-3 Subwoofer Cable 4m RCA to RCA (Used)
AudioQuest's SUB-3 cable features the finest-quality materials to help your high-performance powered subwoofer deliver extraordinarily clear, detailed bass. This triple-balanced cable features three identical conductors for clean signal transfer. Each conductor is a single, unbroken strand of 6.1% silver. Solid conductors eliminate electrical and magnetic interference that can add brittleness to the sound with multi-strand conductor cables.
Dielectric-Bias System
Most higher-end cables require a break-in period before they perform their best. A charge builds up in the insulation through continual use, increasing the efficiency of the cable. This charge can dissipate when the cable's not in use, giving you less than optimal performance until it builds up again.
AudioQuest's Dielectric-Bias System (DBS) eliminates this break-in period. A small battery pack attached to the cable polarizes the insulation with a 36-volt charge, giving you clear, expressive sound from your system every time you turn it on. This also helps eliminate the time delay that can create audio jitter.
Air tube insulation and shielding
Each conductor has its own insulating air tube, which prevents information smearing better than foam insulation. An additional layer of shielding virtually eliminates electronic noise, for the cleanest signal possible.
High-quality connectors eliminate the weakest link
The SUB-3 features RCA connectors made of silver-plated copper. Although this same material can cause high frequencies to sound edgy with full-range analog audio signals, it actually improves bass articulation when used in subwoofer cables. The connectors are fastened by cold welding — a process that uses high pressure and silver paste to minimize signal loss. By contrast, solder tends to impede the signal, and heating the copper conductor can negatively affect its performance.
Spec:
https://www.furutech.com/2020/10/15/20123/
Conditions: 7/10 (USED)
Price: RM450 inclusive postage to West Malaysia
- Number of posts : 5622
» Audioquest Sub-1 Subwoofer Cable 4.5m
» Audioquest SUB-1 Subwoofer Cable (3m)
» Audioquest Sub -X Subwoofer cable 4.5m RCA to RCA (Used)
» Audioquest Sub-1 Subwoofer Cable - 3m and 4.5m
» AudioQuest Sub-1 Subwoofer cable 3m RCA to RCA (Used)
