Power supply modification 120V - 230V
Post by chrishlh on Tue Jul 06, 2010 3:28 am
Can anyone tell me where can I get a good technician to modify my Audio Research power supply from 120V to 230V ?
chrishlh
Club Member
Club Member
Male Number of posts: 28
Registration date: 2009-07-29
Re: Power supply modification 120V - 230V
Post by boxer on Tue Jul 06, 2010 6:29 am
what model is yr item?
boxer
Male Number of posts: 237
Registration date: 2009-03-05
Post by mthoi on Tue Jul 06, 2010 2:49 pm
Easiest would be to get a step-down transformer from 230/240v primary to 120V secondary. Power rating calculation is Voltage * amps (P=V*I) (e.g. if the amp is drawing 4Amps, the power usage is 240* 4 = 960VA). Be a bit more generous on the power rating if possible.
You can probably get a nicely boxed item from Pasar Rd.
mthoi
Male Number of posts: 129
Registration date: 2009-02-26
Post by catal2002 on Tue Jul 06, 2010 4:27 pm
Hi,
Unless not provided by your equipment transformer. a simple solderring or some may use jumper may change from 120v to 240v.Try look at the manual.
If non-provided, step down is the easiest way unless you want to rewiring the transformer.
KLau
www.h1f1.blogspot.com
catal2002
Club Member
Club Member
Male Number of posts: 35
Post by chrishlh on Tue Jul 06, 2010 11:08 pm
boxer wrote:what model is yr item?
Audio Research SP12
chrishlh
Club Member
Club Member
Post by chrishlh on Tue Jul 06, 2010 11:10 pm
mthoi wrote:Easiest would be to get a step-down transformer from 230/240v primary to 120V secondary. Power rating calculation is Voltage * amps (P=V*I) (e.g. if the amp is drawing 4Amps, the power usage is 240* 4 = 960VA). Be a bit more generous on the power rating if possible.
Will stepdown transformer affect the sound performance ?
chrishlh
Club Member
Club Member
Post by mthoi on Wed Jul 07, 2010 12:41 am
From an engineering perspective - no; from audiophile perspective, in my opinion - yes. A step-down transformer in this case is a basic form of line conditioner.
mthoi
