AUDIO RESEARCH VT60 POWER AMPLIFIER (sold)
POWER OUTPUT
50 watts minimum continuous from 20Hz to 20kHz. 1kHz total harmonic distortion typically 1% at 50 watts, below .05% at 1 watt. Approximate actual power available at "clipping": 52 watts (1kHz) (Note that the actual RMS power output is dependent upon both line voltage and "condition" ie: if power line has high distortion, maximum power will be affected adversely, although from a listening standpoint this is not very critical.)
POWER BANDWIDTH
(-3dB points) 15Hz to 40kHz
FREQUENCY RESPONSE
(-3dB points at 1 watt) 3Hz to 40 kHz
INPUT SENSITIVITY
1.05V RMS for rated output
INPUT IMPEDANCE
100K ohms unbalanced
OUTPUT TAPS
OUTPUT REGULATION
Approximately 0.6dB 16 ohm load to open circuit
OVERALL NEGATIVE FEEDBACK
19dB
DAMPING FACTOR
Approximately 14
DISTORTION
SLEW RATE
7 V/µs
RISE TIME
10 µs
HUM & NOISE
Less than 0.5mV RMS - 95dB below rated output (IHF weighted, input shorted)
POWER SUPPLY ENERGY STORAGE
Approximately 184 joules
POWER REQUIREMENTS
105-125VAC 60Hz (210-250VAC 50Hz) 265 watts at rated output, 300 watts maximum, 175 watts at "idle"
TUBE COMPLEMENT
(2 matched pairs) 6550B power output, (2) 6922 driver, (1) 6922 input
CONDITION:8/10
PRICE:SOLD
FOR MORE INFO,PLEASE CALL OR WHATAPPS:
018-9742567 YANG
016-5368723 YUAN
POWER BANDWIDTH
FREQUENCY RESPONSE
INPUT SENSITIVITY
INPUT IMPEDANCE
OUTPUT TAPS
OUTPUT REGULATION
19dB
DAMPING FACTOR
Approximately 14
DISTORTION
SLEW RATE
7 V/µs
RISE TIME
10 µs
HUM & NOISE
POWER REQUIREMENTS
TUBE COMPLEMENT
CONDITION:8/10
PRICE:SOLD
018-9742567 YANG
016-5368723 YUAN
YUAN- Frequent Contributor
- Number of posts : 135
» Audio Research Pre LS7 & VT60 - sold
» Audio Research 300.2 Power Amplifier (used) (SOLD)
» Audio research VT 200 power amplifier (Used)SOLD
» Audio Research V35 power amplifier (used) SOLD
» SOLD - Audio Research 300.2 Power Amplifier (Used)
