Audio Research VSi60 Vacuum Tube Integrated Amplifier
Item: Audio Research VSi60 Vacuum Tube Integrated Amplifier
Condition: 8.5/10. Item is in excellent condition. No dents or scratches.
Price: RM8200 or swap/topup
The VSi60 clearly proves that you do not have to spend a fortune to enjoy truly great sound at home. Built by hand in Plymouth, Minnesota, to the same exacting standards as our renowned Reference series, the VSi60 offers remarkable sound quality and value. Its rated output of 50 watts per channel does not convey the VSi60's ability to drive power-hungry, low-impedance loudspeakers. We designed the VSi60 with the finest full-range speakers, not compact monitors. Dynamics are lifelike with a sense of ease normally associated with larger amplifiers. Yes, its resolving power is surprising, allowing you to hear details that were previously hidden in your recordings, but that resolution is in service of the music — grainless, tonally accurate and refined.
POWER OUTPUT
50 watts per channel continuous from 20Hz to 20kHz. 1kHz total harmonic distortion typically 1.5% at 50 watts, .05% at 0.1 watt. Approximate actual power available at “clipping” 52 watts (1kHz). (Note that actual power output is dependent upon both line voltage and “condition” i.e.: if power line has high distortion, maximum power will be affected adversely, although from a listening standpoint this is not very critical.)
POWER BANDWIDTH
(-3dB points) 12Hz to 70 kHz
FREQUENCY RESPONSE
(-3dB points at 1 watt) 1.0Hz to 80 kHz
INPUT SENSITIVITY
0.47V RMS Single-ended for rated output. (32.5dB gain into 8 ohms.)
INPUT IMPEDANCE
50K ohms Single-ended
OUTPUT TAPS
8 ohms, 4 ohms
OUTPUT REGULATION
Approximately 2 dB 8 ohm load to open circuit
OVERALL NEGATIVE FEEDBACK
7dB
POWER OUTPUT
POWER BANDWIDTH
FREQUENCY RESPONSE
INPUT SENSITIVITY
INPUT IMPEDANCE
OUTPUT TAPS
8 ohms, 4 ohms
OUTPUT REGULATION
7dB
» Audio Research VSi60 vacuum tube integrated amplifier
» Audio Research VSi60 Vacuum Tube Integrated Amplifier
» Sold - Audio Research VSi60 tube integrated amplifier (Used)
» Audio Research VSi60 Integrated Amplifier (Used)
» Audio Research VSi60 Integrated Amplifier (sold)
