VPI JMW-10 3D tonearm
Selling beloved VPI 10" 3D tonearm(without base) RM3,500.00
https://wa.me/+60122738893
https://elusivedisc.com/vpi-jmw-10-3d-tonearm-armwand/
VPI has developed the Worlds First Synthetic Tonearm, created by a 3D Printer!
Have more than one cartridge and a JMW-10 tonearm? Get an extra armtube and enjoy the benefits of multiple cartridges today! Easy to switch, just remove the old armwand and replace with the new one. That simple!
The VPI JMW-10 3D Tonearm is a one-piece structure, from its head shell to its counterweight stub. The 3D Tonearm is manufactured from an epoxy-plastic that is incredibly lightweight, rigid, self-damped and has an effective mass of 10 grams. The VPI JMW-10 3D Tonearm features more detail, greater soundstage, low resonance and excellent musicality! Taking more than 24 hours to print, this new 3D design from VPI will make a huge impact on your oversound quality of the VPI Classic Table!
Fits on the VPI Prime & Classic Turntables Only.
"For comparison purposes, VPI CEO, Harry Weisfeld, played the same five records on a VPI Classic 3 turntable using one of its standard metal tonearms paired with an $8,000 cartridge from German manufacturer, Clearaudio... The 3D printed tonearm with the $220 cartridge punched out some of the Germans teeth before ultimately losing on points, but it made us think long and hard about spending more on a phono cartridge if that much performance can be dragged out of something as entry-level as the Grado Gold. The tonearm/table combination certainly made a huge impact on the overall sound quality ...the impact of the 3D printed tonearm was profound." - Ian White, www.digitaltrends.com
Click Here for the entire review!
"Weisfeld had Grado Gold cartridges mounted in both a standard JMW and a 3D printer version that allowed for quick and easy swaps and A/B listening. Attendees told me the differences were "profound" and all were in favor of the new tone arm." - Michael Fremer, www.analogplanet.com
"Tentatively named the JMW-3D (the suffix refers to the modeling technology used to create its high-tech tooling), VPI's new one-piece tonearm wand/headshell/bearing housing is molded from epoxy resin, which promises to resist sound-coloring resonances while remaining comparatively immune to the problem of energy storage." - Art Dudley, www.stereophile.com
Attention VPI Classic 1-3 Turntable Owners!
Upgrade to the 3D tonearm today! Or... have more than one cartridge and a Classic Turntable? Get an extra armtube and enjoy the benefits of multiple cartridges today! Easy to switch, just remove the old armwand and replace with the new one. That simple!
Special Note: There has been a minor change that has been made with the Prime tone-arm. Going forward, the 3D arm will no-longer have a 3D printed finger lift but instead will include a removable metal finger lift. VPI has performed extensive listening tests and have found there to absolutely be no sonic difference.
Features:
Pivot to spindle: 258mm
Effective length: 273.4mm
Effective mass: 9g
Overhang: 15.4mm
Offset angle: 19.98 degrees
Average RMS distortion: 0.311%
VPI Pure Copper wire
VPI JMW-10 3D Tonearm Armwand Includes:
Armwand
Counterweight
Features:
Effective mass: 9g
Overhang: 15.4mm
Armwand
Counterweight
tongho- Frequent Contributor
- Number of posts : 879
Amplification: Accuphase E470
Speakers: Quad z3
Speakers: Quad z3
Speakers: Quad z3
Speakers: Quad z3
Speakers: Quad z3
Speakers: Quad z3
Speakers: Quad z3
Speakers: Quad z3
Speakers: Quad z3
Speakers: Quad z3
Speakers: Quad z3
Speakers: Quad z3
» SME V Tonearm (used)
» SME Tonearm
» SME M2-10 Tonearm (Used)
» SME M2-9 Tonearm.(Used)
» EMT 929 tonearm (used)
» SME Tonearm
