Projector & Speaker Calibration Ipoh/KL
Hi-Fi 4 Sale - Malaysia / Singapore Audio Forum & Marketplace | www.hifi4sale.net :: Audio & Video Equipment Marketplace :: HI-FI MARKETPLACE - NEWS, HAPPENINGS & EVENTS!
Why need to calibrate the TV ?
Why need to calibrate the Projector?
If you don't calibrate your TV you may find colours are too bright or the contrast between deep blacks and bright whites isn't as stark as it should be. Calibrating your TV means you can achieve the best picture quality possible while also reducing any eye strain you'd get from watching for hours.
TVs need to be calibrated to the room, and a brightly lit living room will have vastly different picture needs than a darkened custom home theater. Whether your TV is fighting with daylight bouncing off of white walls or is settled comfortably in a well-furnished, dark gray cave is the difference that determines what sort of light and color it needs to put out. In bright rooms, gamma (explained below) might be adjusted to a low curve and colors might be oversaturated just a bit to stand out against the ambient light. In a dark room, a higher gamma curve can help preserve shadow details against the lower light level.
KS AV SOLUTION
- Full Setup Home Theatre System
- Audio / Speakers Calibration
- Video/ Projector /TV Calibration
- Home Theatre Diffuser & Acoustic Treatments
Meet us in Ipoh and KL this weekend 2/3-09-23 Sat/Sun. Call Now we can solve all your HT problems.
Most of my customers save thousands of Ringgit after our calibration. Its all your setting - Living Room & Dedicated Room. Too much echoes wrongly set up with auto calibration. Wrong speaker placements no speaker matching . Subwoofer level matching is out. Out out phase and many more. It might look easy but its not. Keep on changing the Amp and speakers without tackling the right area and wasting the money.
Call us now 019-400 4551 we will check your system if its really give you the room target that you want.
We are specialist in
1. Time align each speakers which Auto Calibration can't do due to its limitation.
2. Multiple settings calibration/ tuning minimum 3(max infinity) multiple microphone points which Auto calibration has its limitation.
3. Cross correlate to get actual room response in more larger seating areas which Auto calibrate has its limitation.
4. Target a Optimum Room Curve/Target for your current setup which other auto calibration has limitation .
KS AV SOLUTION Professional Speaker/TV/Projector Calibration.
KS AV Solution - South
Successfully open another Show Room In
3, Jln 14/47, Seksyen 14, 46100 Petaling Jaya, Selangor.Malaysia.
Do Visit us for more full experience.
Person to Contact : +6018-3698826 / 019-400 4551
Monday to Friday 9.00am - 6.00pm.
Saturday / Sunday - Call for Demo.
KS AV Solution - North
Home Theater Demo .
37, Jalan Villa Tanjung Permai 3, Villa Tanjung Permai Batu Kawan. Bandar Cassia . Batu Kawan. Penang.
Person to Contact : 019-400 4551 / +6018-3698826
https:www.facebook.com/KSAVSOLUTION
KS AV SOLUTION
Home Theater Demo .
Kalai7275- Regular
- Number of posts : 89
» Projector & Speaker Calibration Ipoh & KL 30-09-23 and 01-10-23
» Projector&Speaker Calibration IPOH/KL 16/17-09-23
» Professional Speakers Calibration & Projector Calibration Taiping&IPOH
» Speaker Calibration Ipoh/Shah Alam & Kuala Lumpur 12/13 August 2023
» Ipoh / KL Professional Speakers Calibration & Projector Calibration 26/27-08-23
