Naim N-Sub, 350 Watts Class AB, 10″ Sealed Subwoofer, England
Adam Rayner has developed a crush on a very sexy subwoofer – the big and heavy Naim N-Sub.
Made by Naim-Audio, in Salisbury, England.
Solid engineering backed by excellent sound quality.
High Quality build, engineering and performance
6x Presets memory can be stored for different programme material types, personal preferences and listening level.
It houses a 800VA (800Watts) toroidal transformer!
The subwoofer hides all its connections below
Finishes are of a very high quality throughout, with a choice of a light cherry solid wood.
Closed (Sealed) active subwoofer
250mm (10″) long stroke chassis
-extremely stiff cone
-long-travel voice-coil
-large surround to keep its movement pistonic
Frequency Response 20 – 250Hz
350 Watts Amplifier, Class AB
2x Line Inputs with LFE input
1x High Level Input (speaker sockets
RS232 control connection
On the rear panel, with heatsinking for the internal 350W amplifier,
Plus the controls and display, on the front.
Dimension: H385 x W385 x D393 mm
Weight: 29.6kg
Finish: Cherry
WHAT HiFi 5-Star
“We reckon this sub has some of the smartest features for true audiophiles who want to tweak the nuts off their kit”
-Gorgeous rich and textured bass with tight control
-Clever, innovative features
The n-Sub sounds luscious, if a little low on pure might. The bass is rich and accurate, and steers a path through a bizarrely clever set of qualities.
For one, it has that distinctively sweet sound of Class AB amplification. Where the Class D thing can be a bit like being smacked by a bare hand, this is velvet-gloved.
Fast and deep
It drops deeply, too…way deeper than normal music levels, so Naim isn’t being poncy or deluded here. This sub is made for purpose.
More importantly, with all that depth comes speed – the n-Sub is rapid to stop when the bass does. Many big, gutty boomers wobble and whoomp for a bit after the explosion.
Clearly with such a range of inputs Naim intends this subwoofer to be used not just with AV receivers or processors with a dedicated LFE output, but also in stereo systems, whether fed from a preout pair or inserted between a preamplifier and power amp – for which preout sockets are provided – or just connected in parallel with a stereo pair of speakers.
Fascinated by the possibility of using the speakers in a 2.1 configuration as well as in a full 5.1 set-up
The presets on the subwoofer make it easy to switch from a system in which the bass is derived from the left and right channels to one running a dedicated low-frequency ‘.1′ channel, and the speed of the entire set-up delivers high-speed action as well as it does high-quality music discs.
Solid great condition, perfect working condition.
Comes with power cord, remote control, and SoundCare SuperSpike from Norway. (No Box)
RM3,950
Welcome for audition
Subang Jaya ss 14
**Credit Card accepted
Contact 012-6116917
www.facebook.com/Actsessory/
» Wharfedale PowerCube SPC-12 Subwoofer, Sealed, 12" 400 Watts
» BEARD M70 MkII Class A Tube Monoblocks Power Amplifiers - 70 Watts @ 8 Ohms (Hand-made in England)
