Rotel RQ-970BX Moving-Magnet/Coil Phono Pre-Amplifier
Rotel RQ-970BX Moving-Magnet/Coil Phono Pre-Amplifier Empty Rotel RQ-970BX Moving-Magnet/Coil Phono Pre-Amplifier
Post by raymond88 Tue Nov 21, 2023 11:34 am
Item: Rotel RQ-970BX Moving-Magnet/Coil Phono Pre-Amplifier
Condition: 8.5/10. Item is in excellent condition. No dents or scratches. Comes with power cord
Price: RM780 or swap/topup
Rotel RQ-970BX Moving-Magnet/Coil Phono Pre-Amplifier Rotelr11
Rotel RQ-970BX Moving-Magnet/Coil Phono Pre-Amplifier Rotelr10
Rotel RQ-970BX Moving-Magnet/Coil Phono Pre-Amplifier Rotelr12
This outboard phono preamp/equalizer makes the perfect companion to the RC-970 line drive preamp or any digital-based system where phono capabilities need to be added. The RQ-970 accepts both moving magnet and moving coil cartridges and works with a wide range of line-stage preamplifiers, including Rotel's home theater/ surround sound processors.
With the increased use of digitally based audio media, many modern high performance audio components lack the circuitry needed to handle the signals produced by phono systems.
The RQ-970BX is a high-performance phono equaliser, the output of which can be plugged straight into any line level input.
Using the same sophisticated circuit designs and high quality components that have made Rotel a world-wide standard of performance, the type of design used in the RQ-970BX is expensive to manufacture, but it is better for the music.
Total harmonic distortion: <0.004%
Intermodulation distortion: <0.004%
Input sensitivity: 210uV/100ohm (MC), 2.5mV/47kohm (MM)
Phono overload: 16mV (MC), 160mV (MM)
Output sensitivity: 150mV/100ohm
Frequency response: 20 to 20,000Hz
Signal to noise ratio: 70dB (MC), 75dB (MM)
Dimensions: 440 x 72 x 195mm
Weight: 3.1kg
Review
it's a no brainer for someone with a modest vinyl system who wants to keep it that way, financially speaking.
https://www.rotel.com/product/rq-970bx
Number of posts : 10041
Rotel RQ-970BX Moving-Magnet/Coil Phono Pre-Amplifier Empty Re: Rotel RQ-970BX Moving-Magnet/Coil Phono Pre-Amplifier
Post by raymond88 Wed Nov 29, 2023 12:17 pm
