Audio Research VS55 Tube Power amplifier
In good condition 8/10
Selling for RM6500
Swap/Trade in available
Contact Audio Alchemy, Peter 012-3820333
Very musical and with a huge 3-dimensional soundstage.
ARC specifies the power bandwidth for the VS55 as 12Hz to 50kHz, which is impressive for a tube amplifier.
Power output is from 20Hz to 20kHz with total harmonic distortion typically at 1% at 50 watts and below, .05% at 1 watt.
POWER OUTPUT : 50 watts per channel continuous from 20Hz to 20kHz.
POWER BANDWIDTH (-3dB points) : 12Hz to 50kHz
FREQUENCY RESPONSE (-3dB points at 1 watt) : 1.0 Hz to 60 kHz
INPUT SENSITIVITY : 1.1V RMS Single-ended for rated output. (25 dB gain into 8 ohms)
OUTPUT TAPS : 8 ohms, 4 ohms
DISTORTION : 1kHz total harmonic distortion typically 1% at 50 watts, below .05% at 1 watt
POWER REQUIREMENTS : 210-250VAC 50Hz 320 watts at rated output, 500 watts maximum, 200 watts at "idle"
TUBE COMPLEMENT : 4x 6550 power output and 3x 6N1P input and driver.
DIMENSIONS : 14" (35.6 cm) W x 7" (17.8 cm) H x 14" (35.6 cm) D.
WEIGHT : 14.5 kg
Selling for RM6500
WEIGHT : 14.5 kg
- Number of posts : 2532
» Audio Research Classic-60 Tube Power Amplifier ( Used )
» Audio Research D76 tube stereo power amplifier
» Audio Research Classic 60 Tube Power Amplifier
» Sold - Audio Research VS110 tube power amplifier (Used)
