Sold - Audio Research VS110 tube power amplifier (Used)
- Tube complement: 8 x 6550EH power output,
5 x 6N1P input and driver
- Uses fast & low-ESR Nichicon️ capacitors
- Power output: 100 watts per channel continuous
from 20Hz - 20kHz. Approximate actual power
at “clipping” 120watts (1kHz)
- Power Bandwidth: (-3dB) 10Hz - 40kHz
- Frequency response: (-3dB/1watt)
0.8Hz - 40kHz
- Input Sensitivity: 1.1V RMS single-ended for
rated output
(28dB gain in 8ohms)
- Input Impedance: 100K ohms single-ended
- Output taps: 5 way binding posts for 0-4-8 ohm
- Overall negative feedback: 12.7dB
- Damping factor: 11
- Distortion: 1kHz total harmonic distortion
typically 0.5% at 100W, 0.05% at 1W
- Slew rate: 6 volts/microsecond
- Rise time: 10 microsecond
- Hum & noise: Less than 0.2mV RMS - 103dB
below rated output
(IHF weighted, input shorted)
- Powe supply energy storage: 332 joules
- Power requirements: 105-125VAC, 60Hz
210-250VAC, 50Hz
- Dimensions: 17.5” (W) x 7.9” (H) x 19” (D)
- Weight: 27.7kg
- Colour: Black with natural anodized top plate
- Condition: 8/10
Selling : Sold
Payment : COD
0.8Hz - 40kHz
rated output
below rated output
210-250VAC, 50Hz
- Weight: 27.7kg
- Condition: 8/10
Selling : Sold
Payment : COD
Last edited by phchong on Sun Dec 01, 2019 10:05 am; edited 2 times in total (Reason for editing : Sold)
- Number of posts : 3022
» Audio Research SP17 pre & VS110 power amp (sold)
» Audio Research VS110 power amp
» Audio Research Reference 110 Tube Power Amplifier (Used) SOLD
» Audio Research Reference 150 Tube Power Amplifier (Used) SOLD
» Audio Research Reference 110 tube Power Amplifier-SOLD
