Pro Ktv 1560KA with Klipsch RP-500M ii Compact Karaoke Package
Pro Ktv 1560KA with Klipsch RP-500M ii Compact Karaoke Package Brand New. Now Selling At RM6,799. Free Shipping Within West Malaysia.
With 15.6” Built In LED Touch Screen
Built in 120w amplifier and Karaoke Mixer, idea for any Home Theater or audio system
Built in wireless microphone x 2
Song Reverse & Forward
Connect HP by QR code
Singer scoring
Huge Volume Song Storage up to 6000GB
Select song Via Touch Screen Monitor Or Smart Devices
Convinient And Quicker
Song Order Function Up to 200 Songs On Queue
New Songs Update Via Free Cloud Download System
Voice Command
Key Control
Internet Browser
Youtube
Preloaded 57000 Songs ( 4000GB )
450000++ Songs for FREE Download
合法版权
带15.6”电容触摸屏
内置120w 功放 + 混响 ( Mixer ), 适合家庭影院和任何音响使用
内置无线麦 x 2
云端歌库更加齐全
免费新歌下载
歌曲倒带,快进
云端加歌即唱
手机扫码点歌
歌曲评分
触摸屏或手机点歌
云端下载速度更快
语音点歌
音调升降功能
容易安装方便携带
Youtube
刷屏上网
4000GB硬盘 (57000 歌曲)
450000++ 云端歌曲供免费下载,需有Wifi
Pro Ktv WM30 Wireless Mic
UHF Band
Clear Voice Design
Anti Humming features
Rugged And Lightweight Construction
U段传输
高清音质
专业防啸
轻便而坚固结构
Horn loading maximizes efficiently and increases detail while focusing high frequencies towards the listening area. Proprietary Tractrix geometry provides the most efficient transfer of high frequency waves into the listening area. The phase plug and compressed molded silicon face ensure smooth frequency response. When combined, the cleanest, most natural sound possible is created. The second generation increases horn size for a larger soundstage and enhanced directivity.
LINEAR TRAVEL SUSPENSION (LTS) TITANIUM DIAPHRAGM TWEETER
The exclusive Linear Travel Suspension minimizes distortion for enhanced, detailed performance. LTS tweeters are a hallmark of previous Reference lines, making it a core component of some of the best speakers in the world.
VENTED TWEETER DESIGN
The vented tweeter housing reduces standing waves that create unwanted harmonics, resulting in enhanced detail and clarity in high frequency reproduction.
CERAMETALLIC WOOFERS – ALL NEW DESIGN
A signature feature on the Reference Premiere series, Cerametallic woofers are exceptionally rigid and lightweight for minimal distortion and maximum efficiency. New voice coils are 70% larger in diameter resulting in improved power handling and greater cone control for greater linearity and flawless reproduction. New aluminum shorting rings reduce distortion as well as increased power handling and the new motor structure improve transit response with more control with greater speed and accuracy.
TRACTRIX PORTS
Utilizing Tractrix geometry, the Reference Premiere ports allow for the most efficient, fastest air transfer from the cabinet, which reduces port noise for punchier low frequencies. Klipsch Tractrix ports have custom designed inner flares that help reduce air turbulence entering the port. Less turbulent air helps reduce port noise for cleaner, more powerful bass.
NEW AND IMPROVED INPUT PANEL
Featuring audiophile-grade wire and easily accessible aluminum binding posts for any connection type.
FURNITURE GRADE MATERIALS AND FINISHES
Finishes include ebony vinyl and walnut vinyl that boast satin painted baffles with a scratch resistant finish.
STRONG, FLEXIBLE, REMOVABLE GRILLE
Attaches magnetically for an elegant transition from powerful showstopper to discrete performance piece.
CORK PADS
Cork pads replace rubber bumpers for security on a stand or table.
012-2732555 Hew
016-3098668 John
017-2349074 Rick
012-2536225 Peter
012-2309169 Chris
MONDAY - 10AM-6PM
TUESDAY - 10AM-6PM
THURSDAY - 10AM-6PM
FRIDAY - 10AM-6PM
SATURDAY - 10AM-6PM
Pro Ktv KV1560KA
Amplifier Power Output ~ 120w
Measure ~ Dv 12v
Video Output ~ NTSC,75Ω,1VP-P
Sound Output ~ Setreo R/L,1KΩ, 20Hz - 20KHz
Static Noise ~ -105dB
IR Reception ~ INFR , 38KHz
PS/2 Device Input ~ Mouse
VGA Output ~ RGB ,75Ω, Monitor
Externally Connected IR Receiver ~ INFR , 38KHz
Dimension ~ 416mm(W) - 180mm(H) -240mm(D)
Weight ~ 3.5kg
Frequency 400-800M
Distance 100m
Frequency Stability +0.005% (-10ºC ~ 50ºC)
Modulation + 40KHz
T.H.D <0.5% 1 KHz
Frequency Range 50Hz ~ 18KHz + 3dB
Power Output 10mV
Max Input Volume 130dB
Distortion <-55dBc <-40dBc
Frequency Stability 0.005% (-10ºC ~ 50ºC)
Oscillator Quartz Locked
Battery 1.5V(9)
Klipsch RP-500M II
FREQUENCY RESPONSE 50-25kHz +/- 3dB
SENSITIVITY* 92dB @ 2.83V / 1m*
POWER HANDLING (CONT/PEAK) 75W/300W
NOMINAL IMPEDANCE 8 Ohms Compatible
CROSSOVER FREQUENCY 1530Hz
HIGH FREQUENCY DRIVER 1" Titanium LTS Vented Tweeter with Hybrid Cross-Section Expanded Tractrix Horn
LOW FREQUENCY DRIVER 5.25" Cerametallic Cone Woofer with Faraday rings
ENCLOSURE MATERIAL MDF (Internally Braced)
ENCLOSURE TYPE Bass Reflex via rear-firing Tractrix Port
INPUTS Single aluminum binding posts
HEIGHT INCHES (MM) 13.56" (34.4 cm)
WIDTH INCHES (MM) 6.81" (17.3 cm)
DEPTH INCHES (MM) 10.65" (27.0 cm)
PRODUCT WEIGHT LBS (KG) 13.1lb (5.95kg)
FINISH Ebony
Pro Ktv KV1560KA KOD system with Karaoke Mixer & Wireless Microphone 4TB
CopyrightedWith 15.6” Built In LED Touch Screen
Singer scoring
Voice Command
Key Control
Internet Browser
Youtube
合法版权
带15.6”电容触摸屏
内置无线麦 x 2
云端歌库更加齐全
免费新歌下载
歌曲倒带,快进
云端加歌即唱
手机扫码点歌
歌曲评分
触摸屏或手机点歌
云端下载速度更快
语音点歌
音调升降功能
容易安装方便携带
Youtube
刷屏上网
4000GB硬盘 (57000 歌曲)
UHF Band
Clear Voice Design
U段传输
高清音质
专业防啸
轻便而坚固结构
RP-500M II
90° X 90° SILICON COMPOSITE HYBRID TRACTRIX HORNHorn loading maximizes efficiently and increases detail while focusing high frequencies towards the listening area. Proprietary Tractrix geometry provides the most efficient transfer of high frequency waves into the listening area. The phase plug and compressed molded silicon face ensure smooth frequency response. When combined, the cleanest, most natural sound possible is created. The second generation increases horn size for a larger soundstage and enhanced directivity.
TRACTRIX PORTS
CORK PADS
012-2732555 Hew
016-3098668 John
017-2349074 Rick
012-2536225 Peter
012-2309169 Chris
MONDAY - 10AM-6PM
TUESDAY - 10AM-6PM
THURSDAY - 10AM-6PM
FRIDAY - 10AM-6PM
SATURDAY - 10AM-6PM
Pro Ktv KV1560KA
Measure ~ Dv 12v
Weight ~ 3.5kg
Frequency 400-800M
Distance 100m
Modulation + 40KHz
T.H.D <0.5% 1 KHz
Power Output 10mV
Battery 1.5V(9)
Klipsch RP-500M II
FINISH Ebony
- Number of posts : 1323
» BMB CSJ-06 Compact Karaoke Package with Pro Ktv 1560KA
» BMB CSJ-08 Compact Karaoke Package with Pro Ktv 1560KA
» Klipsch RP-500M Bookshelf Speaker
» Klipsch PowerGate + Klipsch R-41M Hi-Fi System Package
» Pro Ktv MK5 Karaoke Package
