Klipsch PowerGate + Klipsch R-41M Hi-Fi System Package
Klipsch PowerGate + Klipsch R-41M Hi-Fi System Package Brand New. Free Shipping Within West Malaysia.
As part of the Klipsch Stream wireless multi-room audio system, anything you plug into the PowerGate can be selected and streamed for playback in other rooms of your house where Klipsch Stream products are located.
Klipsch PowerGate 配有一个 2 x 100 W D 类功放,可以驱动最难驱动的音箱。因此无论您在办公室中使用一对书架式音箱还是连接一对 Klipschorn 音箱,PowerGate 都能为您播放音乐。
作为 Klipsch 串流无线多房间音频系统的一部分,连接到 PowerGate 的任何设备都能选择进行串流,从而可以在您家中 Klipsch 串流产品所在的房间播放音乐。
Features:
特色:
Features:
Klipsch PowerGate
AMPLIFIER POWER 1
2 x 50W continuous / 100W peak
8 ohms, < 0.04% THD+N, 1kHz
2 x 75W continuous / 150W peak
6 ohms, < 0.06% THD+N, 1kH
2 x 100W continuous / 200W peak
4 ohms, < 0.08% THD+N, 1kH
FREQUENCY RESPONSE 20Hz - 20kHz, +
/_ 0.1dB, 6 ohms
SIGNAL TO NOISE RATIO >90dB @ 50W, 8 ohms
INPUTS
USB Audio (Type B Connection)
Wi-Fi (for DTS Play-Fiâ„¢)
BluetoothÂ
Phono pre-amp / RCA analog audio
Optical (TOSLINK)
USB Type A (for firmware updates)
OUTPUTS
L/R Speaker
Subwoofer (LFE)
RCA analog audio
Headphone (3.5mm analog audio)
DIMENSIONS (WxHxD) 10†(25.4cm) x 2.5†(6.35cm) x 6†(15.24cm)
FINISH Black
VOLTAGE 110/240 VAC
WEIGHT 3lbs (1.36kg)
BUILT FROM 2016
INCLUDED ACCESSORIES
Wireless Remote Control
Optical TOSlink Cable
USB Type B cable (for audio)
3.5mm miniplug (analog) audio cable
Universal Power Supply
Klipsch R-41M
FREQUENCY RESPONSE 68Hz - 21kHz +/- 3dB
SENSITIVITY 90 dB @ 2.83V/1M
POWER HANDLING (CONT/PEAK) 50W/200W
NOMINAL IMPEDANCE 8 ohms Compatible
CROSSOVER FREQUENCY 1,730 Hz
HIGH FREQUENCY DRIVER 1” Aluminum LTS tweeter mated to a 90 x 90 square
Tractrix Horn
LOW FREQUENCY DRIVER Single 4” spun-copper IMG woofer
ENCLOSURE MATERIAL MDF
ENCLOSURE TYPE Bass-Reflex via rear-firing ports
INPUTS Single Gold Plated Binding Posts
HEIGHT INCHES (MM) 11.3” (287 mm)
WIDTH INCHES (MM) 5.75” (146 mm)
DEPTH INCHES (MM) 7.9” (200 mm)
PRODUCT WEIGHT LBS (KG) 7 lbs (3.2 kg)
FINISHES Black Textured Wood Grain Vinyl
INCLUDED ACCESSORIES Rubber Feet (4)
BUILT FROM 2018
POWERGATE
Packing a 2 x 100 watt class D amplifier, the Klipsch PowerGate can drive even the most difficult speaker. So whether you use a pair of bookshelf speakers in the office or connect a pair of Klipschorn speakers, the PowerGate will deliver.As part of the Klipsch Stream wireless multi-room audio system, anything you plug into the PowerGate can be selected and streamed for playback in other rooms of your house where Klipsch Stream products are located.
Features:
- 2 x 100 watt class D amplifier
- Wi-Fi connectivity for Klipsch Stream wireless multi-room audio integration
- USB Audio (Type B Connection)
- Bluetooth:registered: wireless connectivity with AAC and apt-X decoding
- Phono pre-amp / RCA analog audio
- Optical (TOSLINK)
- Remote control
- 192kHz / 24-bit D/A Converter
- Headphone Output (3.5mm)
- Subwoofer Output
- Line level Pre-amp output (RCA analog)
特色:
- 2 x 100 W D 类功放
- Wi-Fi 连接可用于 Klipsch 串流无线多房间音频集成
- USB 音频(Type B 连接)
- Bluetooth:registered: 无线连接 AAC 和 apt-X 解码
- 唱机前置放大 / RCA 模拟音频
- 光纤 (TOSLINK)
- 遥控
- 192kHz / 24 位数模转换器
- 耳机输出 (3.5mm)
- 低音炮输出
- 线路电平前置放大输出(RCA 模拟)
Klipsch R-41M Bookshelf Speaker
The R-41M bookshelf speakers offer maximum versatility without sacrificing performance from a small, yet elegant audio solution. Designed as main speakers for a compact living space or surround sound to support a Reference speaker system, the R-41M bookshelf speakers are the ideal choice for your home theater system.Features:
- 1" Aluminum LTS tweeters
- 90x90 Square Tractrix Horns
- 4" Spun-Copper IMG Woofers
- Bass-Reflex via Rear-Firing Port
- Strong, Flexible Removable Magnetic Grille
- Dimensions: 11.3" x 5.75" x 7.9"
TRACTRIX:registered: HORN TECHNOLOGY
Klipsch exclusive 90x90º Tractrix:registered: horn technology ensures that the R-41M high frequency energy is aimed at the listener and reduces artificial reverb or filtering caused by indirect sound bouncing off of walls. Using this proprietary focused technology gives you the best clarity, dynamics, and detail from your movies and music.LINEAR TRAVEL SUSPENSION TWEETER WITH KAPTON:registered: SUSPENSION
Klipsch exclusive Linear Travel Suspension (LTS) aluminum tweeter minimizes distortion for enhanced, detailed performances. Using Kapton:registered:, an extremely light and rigid material, in the tweeter suspension provides high efficiency and improve resolution and detail. LTS tweeters are a hallmark of Klipsch speakers, making them some of the best speakers in the world.SPUN COPPER IMG WOOFERS
Injection Molded Graphite (IMG) woofer cones are exceptionally light while being extremely rigid – providing remarkable low frequency response, with minimal cone breakup and distortion. When paired with the Tractrix Horn-Loaded LTS Tweeter, it provides speaker efficiency highest in its class.SLEEK DESIGN
Exposed fasteners, low profile magnetic grilles and a scratch-resistant, textured wood grain vinyl give the R-41M bookshelf speakers a polished, modern appearance.HIGH QUALITY CABINET DESIGN
Reinforced MDF construction reduces cabinet vibration for less audible coloration and improved sonic accuracy - giving you the ultimate listening experience that's built to last.Interested please feel free to contact:
Klipsch PowerGate
AMPLIFIER POWER 1
/_ 0.1dB, 6 ohms
INPUTS
BluetoothÂ
Optical (TOSLINK)
OUTPUTS
L/R Speaker
Subwoofer (LFE)
RCA analog audio
FINISH Black
VOLTAGE 110/240 VAC
BUILT FROM 2016
Klipsch R-41M
Tractrix Horn
BUILT FROM 2018
- Number of posts : 1336
» WiiM Amp + Klipsch R-40M Hi-Fi System Package
» WiiM Mini + Klipsch R-41PM Hi-Fi System Package
» Klipsch R-51M 5.1 Speaker Package
» Klipsch R-610F 5.0 Speaker Package
» Klipsch R-620F 5.0 Speaker Package
