Speaker DIY
+14
upgraded
vt4c
highcut28
Wikin
gloraglory
adrian4454
ycs
bal
sss333
htkaki
chamts1
wingman
sph
atoz
18 posters
Page 1 of 2
Page 1 of 2 • 1, 2
Speaker DIY
My most recent DIY Subwoofer based on a 100W plate amplifier and 10" subwoofer driver.
Size 16"w X 12.5"d X20"h, approximate volume 50L.
Material-3/4" High density waterproof fibreboard laminated on both side (for wet kitchen cabinet application)
Design-tuned port with adjustable port length,currently tuned at 19hz for music listening.
Cutting- the board is so hard that jig saw or hand saw is a complete no no.
i have to use rotary cutter to do the cutting.
atoz- Frequent Contributor
- Number of posts : 377
Registration date : 2010-01-30
Re: Speaker DIY
Putting the pieces together using industrial grade wood glue.
Binding posts are mount directly on to solid piece of wood for maximum strength
and to ensure airtight quality.
Re: Speaker DIY
Cross and horizontal internal bracing are added.
Note the 2 standing pieces of wood also double up as a support for the
woofer magnet to minimize basket vibrations.
Hard felt and recycled cotton padding are use in different side of the internal walls to cut down standing waves.
Re: Speaker DIY
Internal wiring is QED.
Re: Speaker DIY
" alt="" />
Re: Speaker DIY
Putting the last piece together.
Re: Speaker DIY
I use 2 pieces of wooden Chinese chess bond together and grind to
the shape of cones for the enclosure footing (4 sets).
Re: Speaker DIY
Veneered in black
Note the finished wooden "chess" painted in black.
The 2 pieces of cross bar are layered by foam padding waiting for the driver
to sit on.
Re: Speaker DIY
Time to wire the driver
Re: Speaker DIY
To be continue----
Re: Speaker DIY
Nice work ....
sph- Frequent Contributor
- Number of posts : 336
Re: Speaker DIY
Impressive.... now its time to sit back an admire your handy work. I bet your mind would be reeling on "what can I do next " on this box to get it a notch up .....
cheers
cheers
wingman- Frequent Contributor
- Number of posts : 855
Re: Speaker DIY
Atoz...
Question : How / what did you use to hold the chess pieces on to the drill... ?
thanks
Re: Speaker DIY
Hi Atoz,
Impressive DIY project. Mind to share how your rotary cutter looks like ?
Thanks.
Thanks.
chamts1- Regular
- Number of posts : 79
Registration date : 2009-02-12
Re: Speaker DIY
Rotary cutter, also known as circular saw look like this.
To grind the wooden chess you must first glued and clamp it overnight then
drill a hole in the center and insert a long bolt and fasten the other end with a nut.
Then you can insert the protruding end of the bolt to the machine.
Use rough sand paper to grind.
(I use a rough sanding disk)
Re: Speaker DIY
It is an active sub with the plate amplifier off board.
Reason i do this is because i find built in amp very difficult to do positioning
due to the many cables attached especially the power cord.
Off board means it has only 1 speaker cable attached be it long or short.
I also believe this will minimize the vibration to the amp unit for better
SQ.
SQ.
Re: Speaker DIY
can share the schematic of the active crossover?
which beand of driver you use?
sss333- Regular
- Number of posts : 52
Registration date : 2011-01-06
Re: Speaker DIY
Atoz,
Thanks for sharing pictures of your cutter...
chamts1- Regular
Re: Speaker DIY
I lined the edges with rubber weather strips instead of foam as foam tends to
deteriorate or soften in time.
Re: Speaker DIY
Putting the adjustable spikes in place.
Re: Speaker DIY
The driver is positioned with the 4 screws facing towards the side walls and anchored deep to the vertical plane of the cabinet to add strenght.
With the driver finally in place, it is now time to move to the next step-
the plate amplifier.
Re: Speaker DIY
Hello hello!
Thanks for sharing this wonderful project Atoz. I'm wondering if anyone can point me in the right direction where to buy nice thick MDF or HDF for similar speaker building projects of my own.
Many thanks and gratitude in advance!
Bal.
Bal.
bal- Moderator
- Number of posts : 1275
Speakers: maggie 1.7
Re: Speaker DIY
nice work
can you share how you cut the circular holes for the woofer and ports?
ycs- New Member
Registration date : 2009-06-22
Re: Speaker DIY
Hi,
The woofer hole is done by jig saw while the reflex port is by hole saw.
Re: Speaker DIY
New project, 2 way floor standing speaker.
Preparation for cutting
Re: Speaker DIY
Cutting process
Re: Speaker DIY
Slightly slanted front baffle design
Re: Speaker DIY
Atoz, u r very power~ Thanks for sharing with good photo details. It said a thousand words~
- Number of posts : 722
Re: Speaker DIY
Cutting holes for drivers and reflex port
Re: Speaker DIY
Starting to take shape
Re: Speaker DIY
With the extra long PVC reflex port glued to the front panel
Re: Speaker DIY
2 pieces standing tall side by side
Re: Speaker DIY
View from the back
Re: Speaker DIY
Lining the internal wall with recycled cotton padding
Re: Speaker DIY
Finally it's time to put them together.
Re: Speaker DIY
It is time to put all the drivers in place to proceed for sound tuning
Re: Speaker DIY
5.25" Bass driver is from Castle acoustic and 3/4" soft dome from Vifa
Re: Speaker DIY
Inside is the modified 2 way crossover from the KEF C series speakers
Re: Speaker DIY
After switching with a few different tweeters to match with the bass unit, i finally settled for a less expected combination which is a hybrid design tweeter. I would have to redo the mounting hole to accomodate the squarish magnet at the back of the tweeters.
Re: Speaker DIY
Up and ready for audition!
Re: Speaker DIY
close up pic.
Re: Speaker DIY
hi atoz, how did you make dimension for driver hole before you cut the board?
gloraglory- Frequent Contributor
- Number of posts : 106
Registration date : 2010-04-04
Re: Speaker DIY
gloraglory wrote:hi atoz, how did you make dimension for driver hole before you cut the board?
I measure the inner diameter of the woofer basket and use geometrical set to draw circles on the wood surface to guide the cuttings.
Re: Speaker DIY
It is time to share a bit of my experience with this pair of speakers after a few listening sessions. First test i powered them with my old and faithful NAD 3020 Series 20 amplifier with Epos ES11 as the reference speaker, what immediately draws my attention was the coherence between the midbass and the high frequency units are superb. Worth the hassle of cutting and drilling holes to switch tweeters. Midrange is smooth with a good level of warmth and very well presented. The highs are crisp and detailed without any trace of harshness while the bass lines are clean and extended.
However the down side is that i will need to dail the volume up a little to push this speaker, comparing with my other speakers i estimated it's output sensitivity should be in the 86 to 87dB region only.
Conclusion-I am very satisfied with the initial test results. Next is to power them up with different amplifiers and sources to see if they can perform better.
Re: Speaker DIY
I cannot stop saying good things about this speaker when i switched driving them with my class A+AB 50 watter intergrated Duson PA50 amplifier combo with a Pioneer 20bit cdp. Improvements in every area and proven that the earlier 20 watter NAD is under powered. The soundstage opened up tremendously and bass has more slam and authority. It goes loud without sounding harsh or bright when pushed hard where i can continue listening on a pile of CDs for hours. I believed that it could be due to the natural characteristic of the hybrid tweeters itself that contribute to the overal oganic presentation. I can say that it outshines the ES11 in many areas.
I am eager to test them with more powerful amplifiers.
Page 1 of 2 • 1, 2
» Surround Speaker Cable: QED 'One' Speaker Cable, Belkin AV Speaker Cable, Monster XP Speaker Cable
» Furutech Evolution Speaker II High Performance Audio Speaker Cables - 3m pair
» Cento Wall or Ceiling Speaker Bracket for Bookshelf, Atmos and Karaoke Speaker (New)
» Monitor Audio Silver RS1 speaker & Wire World Polaris speaker cables (Used)
» Surround Speaker Stand. Adjustable Height and Speaker Seat [Sold]
Page 1 of 2
