DLS D3 Lifestyle Floorstand Speaker (Display Uniy)
DLS D3 Lifestyle Floorstand Speaker (Display Uniy) Empty DLS D3 Lifestyle Floorstand Speaker (Display Uniy)
Post by Dicky Ng Thu Nov 10, 2011 4:10 pm
DLS D3 Lifestyle Floorstand Speaker (Display Unit)
DLS D3 is a floor-standing loudspeaker designed for home theatre systems and hi-fi applications. The new edition has a cabinet in black satin finish (also available in white satin).
To satisfy our customers needs we have created a unique type of speaker in different colours to match the home environment.
D3 can be bought without the separate coloured side panels, if you prefer. But if you want something extra there are beautifully shaped side panels in five different colours. They are bought as separate accessories. The priority was to achieve ultimate sound quality with deep bass tones from a slim speaker design, just as for the T3 series.
The exceptional performance of this speaker is a result of advanced speaker-design skills and unique driver technology.
D3 uses the same "transmission line" technique as T3, but with a cabinet of MDF instead of aluminium.
Description : type 2-way transmission line
Impedance :4 ohm
Sensitivity :88 dB/1m, 1W
Frequency range : 48 Hz - 25 kHz
Recommended amplifier : 50 - 120 Watts
Woofer size : 3"
Midrange size : 3"
Tweeter : 28 mm soft dome
Crossover : Butterworth 3rd order
Crossover point (Hz) : 4200 Hz
Dimension (W x D x H) : 123 x 230 x 1230 mm (4,8 x 9,0 x 48,8 inches)
Weight : 8,5 kg / 17,7 lbs
Condition: 8/10
Asking for: RM1990 (New RM 4900)
Contact : 012-3308893 Dicky Ng
DLS D3 Lifestyle Floorstand Speaker (Display Uniy) Dls_d310
Dicky Ng
Dicky Ng
Number of posts : 701
http://www.cmy.com.my
