"Pop sound at speakers" when switching off preamp
+6
skydna
wabun
car o scope
hangleng
kowtim
hijau
10 posters
"Pop sound at speakers" when switching off preamp Empty "Pop sound at speakers" when switching off preamp
Post by hijau Mon Jul 13, 2009 12:04 pm
Afternoon,
Speakers put out a "soft pop sound" when switching off system.
Can anyone advice what is causing this problem?
Shut down step as follow;
Pre Amp "Volume down/mute" => CDP Off => Power Amp Off => Pre Amp Off, and follow by "soft pop sound"
Have try many sequence above seem to be the softest way to shut down system.
Thanks.
hijau
Regular
Regular
Number of posts : 52
Registration date : 2009-03-12
"Pop sound at speakers" when switching off preamp Empty Re: "Pop sound at speakers" when switching off preamp
Post by kowtim Mon Jul 13, 2009 4:09 pm
Hi Hijau
The Rule:
Power amp turned ON LAST, only after turning on everything else first.
Power amp turned OFF FIRST, before turning off anything else.
Some systems do make small gentle "plop" sounds... it is quite normal. If it does not sound gentle, then get someone suitable to come take a look at it.
HTH
Regards
study
kowtim
kowtim
Regular
Regular
Number of posts : 84
Registration date : 2009-05-20
Post by hangleng Tue Jul 14, 2009 5:16 am
You may listen to some gentle plop sound, something like water flowing sound. It is actually DC discharge from caps from your power amplifier.
hangleng
Number of posts : 163
Post by car o scope Tue Jul 14, 2009 6:06 am
Why amps doing DC discharge with pop sound?
Hey, this sounds like my Exposure XX amp.
Have the pop sound sound when turn on and off.
Turn on will get instant pop.
Turn off will get pop sound after few seconds.
car o scope
car o scope
Number of posts : 1081
Post by wabun Tue Jul 14, 2009 6:48 am
it sound like a sticky relay... or leaky condenser. but if follow kowtim rules for last on 1st off for power amp. you shouldnt have any problem..be patient, turn on pre some time onlt turn on power amp
and turn off power amp some time only turn on preamp. the power amp has reservoir capacitor which can store power for few second and some big giant can store for minutes.. Laughing
wabun
Number of posts : 423
Registration date : 2009-03-02
Source(s): Mac mini - Bryston BDP - Calyx DAC 24/192 - Rega P8
Amplification: Jumpan Balance - ARC VT100Mk3 - Musical Fidelity FX
Speakers: JBL 4313B , Harbeth P3esr
Post by car o scope Tue Jul 14, 2009 8:53 am
Well, I guess there will be no alternative for integrated amplifiers with those pop sounds, right?
car o scope
car o scope
Post by skydna Tue Jul 14, 2009 10:45 am
I found some useful info with Google why pop sound generated~~
Basically, the pop is caused by the amplifier stabilising when
switched on. Amplifiers with split supply rails and no output capacitor will not necessaily come up totally symetrically, so some out-of-balance current will flow through the loudspeaker, causing a pop. Amplifiers with a coupling capacitor will have the capacitor charging current going through the loudspeaker, causing a pop. There may be a similar pop on switch-off.
http://newsgroups.derkeiler.com/Archive/Uk/uk.rec.audio/2006-03/msg00706.html
skydna
skydna
Number of posts : 326
Registration date : 2009-02-23
Source(s): Naim
Amplification: Naim
Speakers: ProAc
Post by hijau Tue Jul 14, 2009 3:09 pm
Thanks all.
Will try out some of the method share on above will feed back later.
My other concern will this cause any permanent damage to speaker?
hijau
Regular
Regular
Post by skydna Tue Jul 14, 2009 3:19 pm
hijau wrote:Thanks all.
I think it will be ok as long as no DC current flow through speaker and the pop sound is not loud, for your information Naim amplifier has pop sound from speaker every time when turn on or off~~
skydna
skydna
Source(s): Naim
Amplification: Naim
Speakers: ProAc
Post by azri Wed Jul 15, 2009 5:21 pm
yeah, power amp last On, & 1st Off
azri
azri
Number of posts : 1050
Post by hazy Fri Jul 17, 2009 11:49 am
hi hijau ,
take the several minute when turn off . one by one
power amp 1st then after couple of minute pre.
regard
hazy
hazy
hazy
Number of posts : 541
Post by hijau Fri Jul 17, 2009 3:23 pm
Guys, After trying shutting down Power Amp for 15 min and above then follow by Pre Amp has solve the pop sound from poping.. Very Happy
Thanks..
hijau
Regular
Regular
Post by spinner Mon Jul 20, 2009 12:56 pm
once having this pop sound too on my new avr, a little loud and discomfort. Then, brought back to shop and exchange another one, all smooth and quiet. Smile
spinner
Number of posts : 9
Post by leofric32 Mon Aug 03, 2009 5:43 am
dear all,
I just got my new Naim amp and notice that it does produce pop sound when turn on and off. I can't follow any sequence fr shutting off as the pre-amp does not have any on/off as it draws power from the power amp.
Does all Naim amp produce the pop sound and is it normal?
leofric32
Club Member
Club Member
Number of posts : 26
Registration date : 2009-05-18
