SVS Subwoofer Specials!
Warranty : 3 years (for all new purchases from Aug 2012) instead of 2 years.
1. PB13-Ultra : RM8,499 - Piano Black; Black oak real wood veneer : RM8,399
Features :
* Exclusive SVS Ultra-13" high-output woofer
* 1,000 watt DSP amp with LCD Feature Control
* Computer Assisted Design (CAD) enclosure
* Cast and chromed SVS badging
* Front-firing configuration with co-located vents
* Distinctive curved perforated magnetic grill
* "Stackable" form factor allows easy dual subs
* 3.5" high-flow flared ports CURVE (tm) tuning
* Choice of wood veneers, gloss or text. black
* Two grill choices, fabric or stylish steel
* Selectable Sealed, 20Hz, 16Hz modes
* +/- 3 dB 18 Hz-150 Hz (anechoic) in 20hz mode
* Size: 27” D x 20.5 " W x 22" H (w/o grill)
* Weight: 155 pounds
Review:
1. [You must be registered and logged in to see this link.]
2. [You must be registered and logged in to see this link.]
3. [You must be registered and logged in to see this link.]
4. Highly Recommended in Taiwan Prime AV August 2009
5. Sound & Vision Editor's Choice Award 2008
2. PC13-Ultra : RM7,599
Features :
* SVS designed/built Ultra-13 woofer
* 1,000 watt DSP amp with LCD feature control
* Down-firing woofer with integrated baseplate
* Compliant floor mounts
* Exclusive 3.5" high-flow porting
* Variable tuning (20Hz native) with sealed mode
* Magnetically retained, removable grill
* CNC cut, braced, and hand assembled cabinet
* Architectural-grade black fabric exterior
* Size: Approx. 16” diameter x 46" tall
* Weight: 90 pounds. (105lbs shipping weight)
Review :
1. Home Cinema Choice Reference Status [You must be registered and logged in to see this link.]
3. PB12-Plus : RM6,999
“…the PB12-Plus delivered perhaps the most detailed, subtle performance of all these subs.” - Brent Butterworth, Sound and Vision Magazine, September 09
Features :
New SVS designed/built Plus 12.5 woofer
# STA-800D Sledge™ DSP controlled amp
Flush-mount amp configuration
Front-firing with "curve perf" magnetic grill
Compliant floor mounts, low center of gravity
Proprietary 3" high-flow flared ports
Extra heavy-duty detachable 8 foot power cord
Real wood veneer or gloss black accents
Selectable 20Hz, 16Hz or sealed modes
Size: Approx. 25” deep x 19" wide x 21" high.
Weight: 127 pounds
4. PC12-Plus : RM6,199
Features :
* New SVS designed/built Plus 12.5 woofer
* STA-800D Sledge™ DSP controlled amp
* Exclusive down-firing cylinder design
* Proprietary 3" high-flow flared ports
* Resonance free, protective top grill
* Flush-mount amp configuration
* Extra heavy-duty detachable 8 foot power cord
* Selectable 25Hz, 20Hz, 16Hz or sealed modes
* Size: 40" tall, 16" diameter.
* Weight : 60 lbs
Review : [You must be registered and logged in to see this link.]
5. PB12-NSD : RM3,499
Features :
* SVS 12" NSD AL cone and composite dust cap driver
* 400W RMS STA-400D SVS Sledge™ DSP-controlled amp
* Wide-flared 4” port for maximum air-flow with no artifacts.
* 20 Hz tuning for optimal extension and output on all source material.
* Curved metal grille for a stylish and high-tech appearance.
* +/-3dB 18Hz-150hz anechoic extension
* Size: 17.3" wide x 20.9" high x 22" deep 66lb.
Review of older PB12-NSD:
2. Highly reviewed in Taiwan Prime AV magazine Dec 2009 issue
6. PC12-NSD : RM3,499
Features :
* Small footprint fits into tight locations and is perfect for the enthusiast with limited floor space.
* Built-in, flush-mount amp configuration
* Down-firing woofer with integrated base-plate
* Compliant floor mounts, low center of gravity
* Precision tuned 4" high-flow port
* Resonance free, protective top port grill
* 16.6" high-strength, polymer wrapped enclosure
* Dims: 16.6" diameter, 35.7" tall, 59lbs.
SB SERIES
1. SB12-NSD : RM3,199 (Piano black) RM2,999 (Charcoal black)
SB12-NSD Features:
• SVS 12” NSD AL cone with composite dust cap driver
• 400 watt RMS STA-400D DSP amp, “green” power supply
• CAD design, CNC cut, precision assembled
• Front-firing, sealed, recessed driver, LASER logo
• Compliant floor mounts, threaded/removable
• Assembled and tested exclusively for SVS
• Heavy-duty detachable 8 foot power cord
• Hand crafted charcoal or gloss black finish
• Precision black steel grill
• Freq response : 23Hz -270Hz ± 3dB
• Compact 14.6” H x 14.2" W x 14.2" D. 35lbs
Disclaimer : Finishing might vary from the photos shown above.
For more info, please contact Max 0176778820 or Benjamin 0163229428.
*all prices quoted are based on cash term.
Features :
Review:
Features :
Review :
Features :
Weight: 127 pounds
Features :
* Weight : 60 lbs
Features :
Features :
SB SERIES
SB12-NSD Features:
Last edited by Maxx Audio on Tue Nov 13, 2012 3:50 pm; edited 2 times in total (Reason for editing : Pre-order ended)
» Roksan component specials!
» Sample Post Format for H4S Dealer Specials for New Equipment
» Rythmik FV15HP Direct Servo subwoofer 15″ ported audiophile subwoofer
» Auralex Subdude subwoofer platform and QED Reference subwoofer cable (sold)
» Rythmik F12 Direct Servo subwoofer 12″ sealed audiophile subwoofer
