Blumenstein Audio Orca Fullrange
Blumenstein Audio Orca Fullrange Empty Blumenstein Audio Orca Fullrange
Post by StereoHead Wed May 08, 2013 4:39 pm
Orca Fullrange by Blumenstein Audio, handmade in US. Retail at RM3200. Available in Natural Bamboo and Caramelized Bamboo finishing.
Orcas are true high efficiency speakers, needing as little as 2 watts from a tube amplifier to bloom their entire wall of sound. They can fill large listening spaces yet they possess an inherent purity of sound that can be enjoyed close up, even at distances of less than an arm's length away.
With their unconventionally wide high frequency dispersion angle, the virtual point source fullrange drivers produce a clear and unwavering presentation of the actual space a recording was made in and produce satisfying bass at high or low volume levels, with or without the Orca Subs.
Features:
- Abaca fiber 3" fullrange driver with rubberized cloth surround and large magnetic circuit for high efficiency, excellent detail retrieval, and room presence
- Driver affixed to the exterior of the cabinet using all brass and natural rubber hardware in a specialized tuned and isolated arrangement
- Heavy-duty gold plated brass binding posts for optimal connection quality and longevity
- Bass reflex ports made entirely out of 1" thick bamboo produce powerful bass and lower mid-range realism
- 10-gauge internal wiring
- Finished with a hand-rubbed, non-toxic, food-grade linseed oil and beeswax varnish
- Hand signed and numbered by their maker
Specs:
Impedance: 8 ohms, very stable.
Frequency response: 75hz - 35khz
Efficiency: 89db, conservatively rated!
Dimensions: 5 1/2" W x 7" D x 11 1/4" H
Material: Natural bamboo
Recommended amplification:
Many SET tube amplifiers sound beautiful with the Orcas (particularly the 45, 2A3, 300B, EL84, EL34, etc.). However, they generally need at least a 2A3 (3.5WPC) to fill up an average living room.
A great sounding solid state or digital amplifier up to 100WPC is also a nice pairing, and the Orcas will display the unique strengths of those amplifiers. It's difficult to damage the Orcas' drivers unless you are really trying, but it does become possible above 10WPC output, so please exercise care and common sense with the volume knob when using powerful amplifiers.
Blumenstein Audio Orca Fullrange Blumenstein%2520%252823%2520of%252046%2529
Blumenstein Audio Orca Fullrange 123
StereoHead
StereoHead
Number of posts : 2
Registration date : 2012-12-18
http://www.stereo-head.com
