Arcam Alpha 6 Stereo Intergrated Amplifier (Sold)
Made In England
ARCAM ALPHA 6 INTEGRATED AMPLIFIER
Classic British HiFi amplifier With mains lead.
You probably know all about these wonderful amps but in case you need the tech stuff ………
Arcam produced a series of amps from the Arcam 1 onwards,
winning multiple awards. For sale is my Arcam 6.
- Genuine and powerful 45 Watts / channel.
- 4 selectable Line Inputs.
- Tape Input.
- Plus proper Phono stage for use with a turntable.
( The Phono input can also be switched to become an extra Auxiliary line level input if desired)
- Normal Balance, Bass and Treble controls with a "Direct" button to bypass these if desired for a slightly purer sound.
- Headphone socket.
- Arcam high quality binding posts for speakers which take a standard 4mm banana plugs or you can simply wire direct without plugs for the best sound or if you are not intending unplugging the speakers very often.
Can take two pairs of speakers.
- Normal single pair of speakers plus option to use the switch on front panel to turn on / off a second set.
For example use a second set of speakers in a different room that you don’t need on all the time.
The amplifier is in very good condition cosmetically as seen in photos
Size is approx. 430 x 248 x 74 mm.
Weight approx 4.5kg.
Price : RMSold
Last edited by HiFiLab on Wed Sep 11, 2013 1:48 pm; edited 1 time in total (Reason for editing : sold)
- Number of posts : 2967
» Arcam Alpha 7 Stereo Intergrated Amplifier (sold)
» Arcam Alpha 8 Intergrated Amplifier and Alpha 8 Power Amplifier Combo (sold)
» Arcam Alpha 10 Intergrated Amplifier (used) - SOLD
» Arcam Alpha 5 Plus intergrated amplifier (sold)
» Arcam A65 Plus Stereo Intergrated Amplifier (sold)
