Radio Shack Digital Sound Level Meter (SOLD)
Hi-Fi 4 Sale - Malaysia / Singapore Audio Forum & Marketplace | www.hifi4sale.net :: Audio & Video Equipment Marketplace :: Other Non-Audio/Video Stuff
Features:
3-Digit Liquid Crystal Display - Makes it easy to read sound measurements.
21-Dot Analog Bargraph - Gives you a visual representation of the measured sound.
Mode/Condition Indicators - Show you the current mode and status of the meter.
Wide Sound-Measuring Abilities - Measures from 50 dB to 126 dB SPL with seven Ranges.
Average or Maximum Sound Level Display - Continuously shows the average or maximum sound level: per second with digits, per 0.2 or 0.5 seconds with the bargraph.
Tripod Ready (Not Included)- Lets you attach the meter to a tripod (1/4-inch) for more accurate sound measurements.
Data Hold - Lets you freeze a measurement on the display.
Integrated Averaging - Measures the integrated average, and holds the maximum and minimum sound levels for a preset period.
Underrange and Overrange Indicators - Show you when the sound level reading is under or over the selected range.
A and C Weighting - Lets you select either type of weighting to suit the purpose of the measurement.
Selectable Bargraph Response - Lets you select a slow (0.5 second) or fast (0.2 second) bargraph response.
Peak Level Indication - Shows you when the meter registers the maximum level measurement on the bargraph.
Reset Button - Lets you clear the current measurements from the meter's memory and begin a new measurement.
9-Volt Battery Operation - Lets you power the meter with a 9-volt battery. (battery Not Included)
Phono Output Jack - Lets you connect the meter to your stereo system or test equipment.
Low-Battery Indicator - Shows you when the battery needs to be replaced.
Condition: Used but good.
Price: SOLD
Contact: 016-6396268
Thanks for viewing
kw100- Regular
- Number of posts : 54
» Where to buy Radio Shack Sound Pressure Level meter
» RadioShack Digital Sound Level Meter (SOLD)
» Digital Sound Pressure Meter ( sold)
» noise level of our rooms and sound pressure level of music playback
» crackly sound from sliding level control ( sound mixer )
