Caustic 600SE 2CH Power Amp (Used)
Hi-Fi 4 Sale - Malaysia / Singapore Audio Forum & Marketplace | www.hifi4sale.net :: Audio & Video Equipment Marketplace :: Car Audio: For Sale & WTB
A rare, powerful and clean sound Caustic 600SE 2CH Power Amp (Used) for sale:
Product Features:
MULTI-FUNCTION CIRCUIT DESIGN
These 2-channel amplifiers have built-in high-pass/low-pass filters. With the filter switched off, they can be configured as a quasi 3-channel amplifier.
BUILT-IN ELECTRONIC CROSSOVER WITH CONTINUOUSLY ADJUSTABLE CROSSOVER FREQUENCIES
You have a choice of selecting full-range, high-pass only or low-pass only. These filters feature 18dB per octave high-pass and low-pass. Furthermore, the crossover frequencies are continuously variable for fine-tuning of your audio system.
OVER-CURRENT, SHORT CIRCUIT AND DC OFFSET PROTECTION
The sophisticated circuitry monitors abnormal conditions such as voltage spikes, oscillation, DC offset or short circuit. When any of these undesirable conditions exceed their respective preset limits, the circuit will shut down the audio system briefly and lights up the protection indicator to identify the problem for immediate attention. Once the problem is resolved, the amplifier will resume operation automatically.
HIGH SPEED HIGH CURRENT MOSFET SWITCHING POWER SUPPLY
High current MOSFET transistors are used in the power supply section to minimize internal heat and maximize reliability. Furthermore, the combination of the very high pulse-width-modulated (PWM) switching frequency and the extra large filter capacitance guarantees stronger and deeper transient bass response.
TRIPLE DARLINGTON HIGH CURRENT/HIGH VOLTAGE FULLY COMPLEMENTARY OUTPUT STAGE
Complementary output stage audio circuitry has long been a hallmark of "exotic" home amplifier design. Coustic is one of the very few car audio manufacturers to incorporate such elaborate audio circuitry into its power amplifiers. Triple Darlington configuration ensures the audio amplifier is always operating at its optimum conditions.
LINE OUPTUTS
The full-range line outputs can be used to feed signals to another amplifier for your future expansion or for setting up a more sophisticated system.
WIDE RANGE INPUT SENSITIVITY ADJUSTMENT
The input sensitivity level of the Coustic 600SE amplifiers can be easily varied from as low as 100mV to as high as 5.0 volts by adjusting the control on the End Panel.
HIGH/LOW IMPEDANCE INPUT
If you are using a floating or common ground car radio, these amplifiers are the best fit for your system. They are compatible with floating or common ground car radio speaker outputs even without a floating ground adapter. If, in the future, you decide to change to a higher quality after market source unit with RCA pre-amp outputs, this same amplifier is there to give you improved frequency response and better sonic performance.
STABLE INTO 2-OHM LOADS
With the over-designed power supply section and a sophisticated power management circuitry, these amplifiers can maintain their stability even in the highly reactive low impedance environment.
ADJUSTABLE BASS BOOST
This feature allows you to enhance the bass performance of your sound system. The control is continuously variable with a maximum boost level of 18dB.
Item come with original packing box.
Condition: 8 / 10
Asking Price: RM1,000
Contact: 013-8799422 (Mr. Chan) WhatsApp
Thank you.
Product Features:
LINE OUPTUTS
Condition: 8 / 10
Thank you.
chancw- Club Member
- Number of posts : 25
Registration date : 2014-07-02
chancw- Club Member
» Balanced Audio Technology VK-600SE power amplifier SOLD
» WEIDUKA AC8.8 / 3 In 1 AC Power Purifier AC Power Filter 6 Display with 3M DIY Furutech Cable Power Cord
» Audio Power Industries Power Wedge 214p power conditioner (Used)SOLD
» Torus Power IS Series High-Power Isolation Power Conditioner
