QED Silver Anniversary XT Bi-wire
SOLD
5 star awards from speaker cable from hifi reviewer
Working condition : perfect 10/10
Cosmetic condition : 6/10 ( I wrap it with EuroTap Stretch 23 - high voltage electrical insulating EPR tape for lasting use. Please note this is wrap is a permenent for lasting use)
Factory plug terminated using metal type AirLoc
Lenght : 3meter each. A pair only RMSOLD. Including postage.
Prefer if you can see the cable yourself.
Whatapps me for more pictures - 0163040334.
Review from WhatHifi.com:
Take an award-winning speaker cable, double up on the conductors to make it biwire, and the result is this version of QED's Silver Anniversary XT. Does it sound good? You bet!
Transparency is exceptional for the money, though the presentation is just a little on the lean side. It's still a worthy five-star product, though.
Specs:
High performance low density polyethylene dielectric. Cuts down on the amount of audio signal energy lost due to cable capacitance. X-Tube™ technology At low frequencies both X-tubeTM and conventional stranded/solid core speaker cable convey signals in a linear way. However, at higher frequencies, X-tubeTM retains a near-linear signal transfer, whereas the conventional stranded/solid core cable fails to conduct higher frequencies uniformly across the entire conductor area. The result is greater detail which would other wise be lost in ordinary cables.
Bi-Wire
Separate feed to tweeter and bass/mid drive units for improved loudspeaker control and performance
Specs:
Bi-Wire
Last edited by Franklin Gorden on Sat Aug 09, 2014 12:13 am; edited 1 time in total (Reason for editing : item sold)
Franklin Gorden- Frequent Contributor
- Number of posts : 533
Registration date : 2014-07-29
Source(s): Naim CD5 & CD3.5
Amplification: Naim Pre Power & Intergrated
Speakers: Harbeth HL5 Reference
» QED Silver Anniversary Bi wire (used)
» QED Silver Anniversary XT bi-wire speaker cables (New)
» QED Silver Anniversary Bi-wire 4 to 4 Speaker Cables 4m pair (Used)
