10" DIY OB speaker
+2
sph
atoz
6 posters
10" DIY OB speaker
My hands started to feel itchy after i got hold of a pair of big 10" full ranger.
Having chatted with a speaker guru and a quick glance at the DIY project pictures posted in the web, decided to explore the long wanted OB project myself.
atoz- Frequent Contributor
- Number of posts : 377
Registration date : 2010-01-30
Re: 10" DIY OB speaker
Drivers are from the Magna Acoustica speakers, according to source they were modified (coated with special resin) CH250 supplied by a French raw speaker manufacturer Ciare.
Paper Specifications are pretty impressive for a 10 incher with a claimed frequency range from 60-18khz and capable to handle 150 watts. Efficiency is high at 96db meaning small tube or monster solid state amps can also be paired with.
Sounds interesting enough! lets play.
Put up some photos as you go along building it.
Cheers.
Cheers.
sph- Frequent Contributor
- Number of posts : 336
https://i.servimg.com/u/f39/14/81/45/19/img_2028.jpg
The cutting begins ------------ noisy and dusty work
https://i.servimg.com/u/f39/14/81/45/19/img_2029.jpg
1" thick solid Sungkai wood (Peronema canescens) hardwood.
https://i.servimg.com/u/f39/14/81/45/19/img_2030.jpg
more cuttings
more cuttings
To minimized the front and back waves phase cancellation in narrow baffle, i install folded wings at the sides.
The 2 wings are not equal in widths, 1 side is 4" and another is 5" in mirror image. The difference allows me to play with positioning and toe-in or swap left right for tuning.
Cutting thru the solid 1" thick wood is no easy job.
The edges are rabbeted to avoid sharp corners.
Very skillful:)
vt4c- Frequent Contributor
- Number of posts : 149
This is precisely what we need more of in our fine forum. Bravo Atoz. One up for you.
Bal.
Bal.
bal- Moderator
- Number of posts : 1275
Speakers: maggie 1.7
Thank bros
Grooved to breakup the boring big wide panels.
Hi Atoz,
Very nice wood working! Have u mount up the driver and listen to it yet? Care to share where did you get the solid wood from?
regards
SF
regards
SF
phsf98- New Member
- Number of posts : 6
Registration date : 2009-09-09
Source(s): Mytek DAC
Amplification: DIY EL84 SE amp, DIY 300B amp
Speakers: DIY coral flat8 BR
https://i.servimg.com/u/f39/14/81/45/19/img_2047.jpg
Have the base installed.
phsf98 wrote:Hi Atoz,
regards
SF
Drivers mounted, undergoing tuning in the listening room at the moment. Will update later.
I bought the solid wood piece from a furniture factory.
https://i.servimg.com/u/f39/14/81/45/19/img_2048.jpg
https://i.servimg.com/u/f39/14/81/45/19/img_2050.jpg
https://i.servimg.com/u/f39/14/81/45/19/img_2051.jpg
The back side.
The back side.
https://i.servimg.com/u/f39/14/81/45/19/img_2052.jpg
Drivers finally mounted in place, can't wait to wire them to test!
https://i.servimg.com/u/f39/14/81/45/19/img_2053.jpg
https://i.servimg.com/u/f39/14/81/45/19/img_2054.jpg
Listening first impression?
Enough to put a smile on my face immediately.
To be continue..........
Initial listening session summarized as below:
The first thing that struck me was the enormous soundstage they throw out extending at least 3' to the left and to the right side of the speakers.
It has also a reasonable top to bottom frequency extension to be considered a real fullrange speakers.
However the soundstage lacks depth and the overall tonality leans toward to the bright side due to the driver's frequency bump in upper midrange as expected. I know this can be corrected easily using damping materials or perhaps a simple notch filter in the line.
I am very happy with the initial performance and feels rewarding enough to further improve them.
Associated equipments in the initial testing:
Pioneer CDP
Yaqin tube buffer
Audiolab intergrated
Pioneer CDP
Yaqin tube buffer
atoz: where did you source the wood from?
chinlai- Club Member
- Number of posts : 36
Registration date : 2012-07-31
Source(s): Denon
Amplification: Yamaha
Speakers: Monitor Audio
Answer in 1 of the post above.
which furniture factory bro?
Source(s): Denon
» Surround Speaker Cable: QED 'One' Speaker Cable, Belkin AV Speaker Cable, Monster XP Speaker Cable
» Furutech Evolution Speaker II High Performance Audio Speaker Cables - 3m pair
» Cento Wall or Ceiling Speaker Bracket for Bookshelf, Atmos and Karaoke Speaker (New)
» Monitor Audio Silver RS1 speaker & Wire World Polaris speaker cables (Used)
» Surround Speaker Stand. Adjustable Height and Speaker Seat [Sold]
