KT88 Single Ended Class A Tube Amplifier Hand Made
All new designed series, Single Ended KT88 full class A Single-Ended tube amplifier, major circuit improvements with dual monaural operation all the way from power supply to output stage, top with imported audiophile components such as Philips Mullard mustard coupling caps, Rifa Sweeden cathode caps, Siemens Epcos bypass caps and Alps sealed stepped attenuator for accurate volume control just to name a few. Vintage looked stereo illuminated VU meter included
Sovtek 6SN7GT driving JJ KT88 in Single-Ended full class A operation, churning out a clean, detailed, powerful yet warmth tube sound that the Hi-Fi enthusiast craze for. Powerful tube rectified power supply with EH / Winged 'C' 5U4G, dual filter chokes and dual Philips BC power filter caps eliminating cross-talk and
load imbalance that normal integrated tube amplifier suffers. All tubes are carefully tested and matched with tube tester during selection.
Each of this hand-made amplifier is carefully checked & tweaked before undergoing both electronic and listening tests to ensure its dynamic parameters are met. Finally each amplifier is run to allow the valves to blend in with the components in harmony.
Specification:
• All hand wired point to point
• No printed circuit board to ‘colour’ sound
• Japanese ALPS sealed stepped attenuator
• 2 RCA inputs with selector
• Pure Class A operation
• 2x matched pair Russian JJ KT88 output tubes
• 2x matched pair Russian Sovtek driver tubes
• 1x Russian EH 5U4G rectifier tube
• 2x 18W RMS continuous power per channel
• Freq response 10hz-20kHz +/- 0.5dB
• 4 and 8 ohm loudspeakers connection
• High quality imported components and heat-sinked cathode resistor in use
• Silver coated cable on HT & audio path
• Custom hand wound output transformers
• Ceramic valve holders for minimum leakage
• Full Aluminium casing with Burmese Teak wood sides
• Back-lit Stereo VU meter on power output indication
• Centre tapped heater circuit for super quiet background
• Gold plated pure copper Input & speaker terminals
Available for order now at just RM2900.
Options:
1. Built-in Phono Input for turntable add RM300
2. Use China Shuguang Tubes for less RM150
Dealing method: 40% deposit for order confirmation, 3-4 weeks to complete with testing and run in.
Contact me at 0124755833 or visit [You must be registered and logged in to see this link.] for more information.
Specification:
Options:
Last edited by pckhoh on Sun Sep 14, 2014 2:42 pm; edited 1 time in total (Reason for editing : Font change)
pckhoh- New Member
- Number of posts : 5
Registration date : 2012-08-23
» 6L6GC Tube Amplifier Class A SE Hand Made
» Synergy 6F3 Class A Single Ended Tube Amplifier (NEW)ALL 5 UNITS SOLD.
» MONA A1 Class A KT120 Tube Single-Ended Integrated Amplifier With Bluetooth 5.0
» Musical Fidelity X-Pre ( 4-input class A single ended Triode tube pre-amplifier )
» Yaqin MS-500B Tube Class A Single-Ended Hifi Integrated Amplifier
