6L6GC Tube Amplifier Class A SE Hand Made
Known as the super musical and low distortion 6L6GC tube amplifier, Russion made JJ 6L6GC audio output tubes, driven by low noise JJ ECC82, designed in single Ended pure class A operation, built on a full aluminium casing, with over-sized transformer, ensuring continuous powerful musical amplification with lowest noise induced from equipment and wiring around.
8W x2 RMS output, 4 or 8 ohm speaker terminals connection, best match with 89db and above sensitivity speaker for that ultimate smooth tube sound experience with balance bass and high.
Audiophile grade imported components such as Philips Mullard Mustard coupling capacitors, Roedenstein bypass capacitors and Nippon Chemicon big filter caps are used in the entire amplifier ensuring high quality sound reproduction and long lasting years of operation. "All tube design" including 5Z4 full-wave tube rectifier with choke for stable and low noise power supply, preserving dynamic and full tube warmth tonality.
Order to build, approx. 3 weeks for delivery, including custom build, testing and sound tuning.
Each of our hand-made tube amplifier is carefully checked & tuned before undergoing both electronic and listening tests to ensure optimum performance. Tubes are tested and matched with tube tester for balance L/R channel operation.
RM1500 only. Dealing method: 40% deposit for order confirmation, full payment upon completion.
Audition test by appointment only. call/text/whatapp/line/wechat me for more info 0124755833
pckhoh- New Member
- Number of posts : 5
Registration date : 2012-08-23
» KT88 Single Ended Class A Tube Amplifier Hand Made
» BEARD M70 MkII Class A Tube Monoblocks Power Amplifiers - 70 Watts @ 8 Ohms (Hand-made in England)
