ACROLINK 6N-A2110 II RCA Cable (Used)
ACROLINK 6N-A2110 II RCA Cable (Made In Japan) (Used)
Condition : 7.5/10 cosmetic, 100% working
Price :SOLD
Conductor Resistance17 m/meter
Electrostatice Capacitance: 52pF/meter
Standard Lengths (in meters): 0.6, 1.0, 1.5, 2.0
Contact : Ken 016-2281588 ( sms/call/whatsapp ) COD In KL Area. Thanks For Viewing
Price :SOLD
6N-A2110 II
True Purity
Various manufacturers claim to produce ultra high purity, 6N (99.99997%) copper; however, different refining processes yield materials that vary greatly in both the composition of impurities and crystalline structure.
Most of the "so called" 6N and 7N materials are not measured comprehensively. Glow Discharge Mass Spectrometry - an extremely powerful tool for performing ultra-trace elemental analysis has been applied to Acrolink's 6N pure copper. The results in the accompanying table demonstrate that Acrolink has achieved an unrivalled standard of purity.
The Effect of Impurities
Minute impurities create variations in impedance, inhibiting the ability of a cable to achieve extended frequency response. Responsible for meeting the needs of leading edge computer and aerospace technology, Acrolink has developed a multi-stage process that removes each impurity individually. Applying this to audio they have been able to achieve flat frequency response to 18 GHz in their Mexcel series!
Stress-Free
After the cable core is formed, the Acrolink Stress-Free process is applied in a clean, oxygen free environment. This imparts permanent self-annealing properties: No matter how often the cable is bent or impacted, it will always return to its original relaxed state (uniform crystalline structure).
Plugs
Made by Sanpo Shindo with their patented ecological brass which contains silicone rather than lead. With virtually no resonance due to its high damping factor, remarkably clear, fast and high resolution sound is realized with a very low noise level. Precision machined with high quality 24 k Gold plating.
Balanced 2-core interconnect cable: the fundamental structure for high quality audio cable, providing an equal environment for both the hot and cold conductors. Acrolink has designed optimally sized and spaced conductors.
Dielectric
A new polymer polyolefin, presently the best material available, has been chosen for the insulator for its extremely low dielectric constant (1/3 of polypropylene and 1/4 of PVC).
Resonance Absorption
Proper absorption of resonance is one of the key factors in determining final sound quality. Acrolink has focused on this issue for many years and developed tremendous expertise. Materials are carefully selected for each individual design in order to achieve perfectly balanced and effective absorption.
Since signal transmission is carried out on the electromagnetic field, the 6N-A2110 II interconnect is designed to generate optimum field formation, minimizing the adverse effects of electrostatic capacitance, inductance, dielectric constant, etc.
6N-A2110 II Specifications:
Conductors: 6N Copper, 0.18mm X 21 strands X 2 (red and black), Cold Side : 6N copper 0.18mm X 24 strands Shield: 0.12mm X 24 strands X 5 braids, Drain line: 0.08mm X 19 strandsConductor Resistance17 m/meter
ken6172- Dealer\Reseller\Trader\Service Provider
- Number of posts : 272
Registration date : 2009-12-19
Re: ACROLINK 6N-A2110 II RCA Cable (Used)
Item Sold Thanks For Viewing.
» Acrolink 6N-A2110
» Acrolink 6N-D5050II Coaxial Cable (Used)
» Acrolink 6N P4030 Power Cable-used
» Acrolink 6N-1400ii speaker cable
