FM Acoustics Resolution Series 155 Preamp
2 posters
- Superb natural reproduction of music
- Absolute transparency
- Unparalleled freedom from noise & interference
- Proprietary enhanced Class A circuitry
- Fully discrete circuitry using special curve-tracer analysed and listening-selected semi-conductors
- Tremendous headroom and reserves in input signal handling capability
- Zero overall feedback / feedforward
- Discrete Class A tape send and return buffers garantees superior recordings
- No more matching problems between electronics and cables
- Outputs drive any type of load and long cables with perfect reproduction and stability
- Neutral; no colouration
- High dynamic reserves
- All input & output impedances are perfectly linear over full frequency range
- Precision output level control; no stepped attenuators, relay type or inferior sounding optical volume control
- External transformer prevents stray fields
- Low impedance, high stability power supply regulation
- Hand-selected and individually matched components of DIN, IEC & MIL standards
- Totally modular concept, guaranteeing that the FM 155 does not become obsolete
- The Resolution Series 155 is the ultimate line stage/preamplifier for use with single ended equipmentÂ
The preamp are in very good condition and its come with original box .
Asking: RM29,800.00
Please contact / whatsapp 0168008896 Mr Tan for more info.
GOOD LUCK!
https://3.bp.blogspot.com/-yLzyPvTljfU/V01dWVONLEI/AAAAAAAABr0/CsgUgNhF4W0Nty-Bj5y8R4EN4QQar3IEACLcB/s400/449d20e682b59a7b28ecf9770d685822.jpg
vintageguys- Dealer\Reseller\Trader\Service Provider
- Number of posts : 789
Amplification: WESTERN ELECTRIC 91B MONO POWER AMP ( WE247A IPT)/ WESTERN ELECTRIC 7A MONO AMP / WESTERN ELECTRIC 14A MONO AMP
Speakers: Altec A4 FULL WINGS 803B HORN+288C / 515B+515C / N500-F DEVIDING NETWORK
Re: FM Acoustics Resolution Series 155 Preamp
Vintage guys...for God's sake 215 posts ... your post is ABOUT TO BE DELETED. Even if item is reserved you MUST still keep the price visible until sold. you have one hour to amend, or this post will be deleted. You have been warned about this before. If you have not read the guidelines, NOW would be an excellent time to do so. Any more transgression on your part regarding forum rules will no longer be entertained with a warning, your post will be deleted.
bal- Moderator
- Number of posts : 1275
Speakers: maggie 1.7
noted with thanks !
sorry its my mistake
» Boston acoustics vr40 lynnfield vr series( Made in USA)
» REL Acoustics Longbow Wireless System (For S-Series Subwoofer)
» Q-Acoustics 1000 series speakers ( Demo & New)
» Q Acoustics 3000i series and Marantz SR5013 (used)
» NAD 1020 series 20 preamp
