JBL Control 1
JBL Control 1
JBL Control 1 (used but working) - U$30 / pc + shipping from China (low chances of tax using special channel)
* Limited quantity
* Conditions - 6/10
http://www.jbl.com/loudspeakers/CONTROL+ONE_.html
Take great audio performance throughout your house.
You can have the world-famous JBL® sound anywhere you want it: tucked away in a bookshelf, on your desk, in the kitchen, in a home theater or studio, mounted easily up on a wall or even as part of a multiple-room home music system. The rugged, compact enclosures feature a 4" woofer and a 1/2-inch titanium laminate tweeter for a smooth frequency response of 50Hz to 20kHz. The JBL® Control® One speakers have a peak power-handling capacity of 200 watts and include magnetic shielding to prevent interference with your TV or computer display. Put them anywhere. If you need big, accurate, full-range audio with a simple, low profile, this is your answer.
Nominal Impedance 8 Ohms
Maximum Recommended Amplifier Power 100W
Sensitivity (2.83V@1m) 89dB
Frequency Response 80Hz – 20kHz
Power Handling (Recommended) 50W
High-Frequncy Transducer 1/2" (12mm) Titanium-laminate, magnetically shielded
Width (mm) 155
Weight (lb) 5.4
Weight (kg) 2.4
Height (mm) 228
* Limited quantity
* Conditions - 6/10
Audio Specifications
Speaker Specifications
Low-Frequency Transducer 4" (100mm) Magnetically shieldedHigh-Frequncy Transducer 1/2" (12mm) Titanium-laminate, magnetically shielded
Dimensions
Depth (mm) 139Width (mm) 155
Weight (lb) 5.4
Weight (kg) 2.4
Height (mm) 228
» Thrax Dionysos Control Pre-Amp with Remote Control (Used) SOLD
» vintage JBL Control SB-5 & 2 pairs Control 5 speakers(usa)
» JBL control 5 compact control monitor loudspeaker
» JBL SUB Control SB-5 n 2 pairs Control 5(vintage)
» JBL Control 5 (Sold)
