WireWorld Matrix 2 6-Way Power Distribution Block and Stratus 7 Power (UK Plug)
WireWorld Matrix 2 6-Way Power Distribution Block and Stratus 7 Power (UK Plug) Empty WireWorld Matrix 2 6-Way Power Distribution Block and Stratus 7 Power (UK Plug)
Post by john_online_shop Mon Dec 18, 2017 2:57 pm
Brand new unit
Estimate Price: RM1,299
Contact: John 0124831410
Visit website for other model
Note: This item will send from oversea and will take 14 - 21 days to received the item
Please contact me first to check stock availability with my oversea supplier.
WireWorld Matrix 2 6-Way Power Distribution Block and Stratus 7 Power (UK Plug) Wireworld-matrix-2-6-power-distribution-block-stratus-7-power-bluezircon-1708-01-bluezircon@23
WireWorld Matrix 2 6-Way Power Distribution Block and Stratus 7 Power (UK Plug) WireWorld
WireWorld Matrix 2 6-Way Power Distribution Block and Stratus 7 Power Cable (1 Meter )
The Matrix v2 is a multi-way power distribution block which is particularly useful for home theatre installations where there are never enough power outputs. Its compact size allows for easy placement behind or to the side of audio/video racks. The Matrix features selectable mounting options via a bracket re-orientation and therefore is one the most user friendly product on the market.
The Matrix v2 is a perfect solution for those requiring a cost effective way to remove mains noise and distribute power efficiently. When combined with the WireWorld Series 7 power cords it will enhance and improve the performance levels of the likes of Video tuner, DAB tuners, DVD players, Flat screen displays, Game consoles, computers, CD players, Projectors and a variety of other sources and displays.
WireWorld Matrix 2 6-Way Power Distribution Block and Stratus 7 Power (UK Plug) Mounting_bracket
Specification
- Star-Wired
- Six 13A high quality outlets
- Oxygen-Free Copper wiring
- DeoxIT Gold treated
- Rack mountable
- User selectable mounting options via bracket re-orientation
WireWorld Stratus 7 Mains Cable
The Stratus 7 is an entry level upgrade power cord which features Oxygen-free copper conductors and molded connectors with silver-clad copper alloy. A perfect choice for entry level Audio systems and Video displays.
Wireworld power cords are designed to solve a completely different set of problems to audio and video cables. An ideal audio or video cable would pass the entire frequency range without alteration. However, an ideal power cord would pass only the 50Hz or 60Hz AC power, while blocking all other frequencies, to prevent power line noise and harmonics from degrading the sound and imaging quality of the system.
Wireworld power cords feature superior shielding & moulded IEC plug featuring silver-clad copper alloy contacts as standard, except Platinum Electra which is fitted with wired IEC utilising OCC®️ silver-clad copper contacts.
All of the Series 7 cables feature Composilex 2 insulation technology, which minimizes the triboelectric noise produced by conventional insulation materials. Many understand that insulation materials influence the performance of a cable. Wireworld created unique polymer composites designed specifically to optimize fidelity. The benefits of Composilex 2 are especially noticeable on Series 7 Power cables where the reduced interference preserves the purity of the original sound thereby greatly improves performance. These new materials push the boundaries of there expectations for fidelity by letting us hear, see and feel more than ever before.
To achieve that objective, they developed the Fluxfield Technology™️, a unique internal structure incorporating Composilex®️ 2 insulation materials, which maximizes inductive and capacitive filtering to absorb power line noise and damp the electrical resonances that other cords and power conditioners cannot tame. Among the innovations of this design are dual low-impedance shields, which are closely coupled to the conductors to cancel unwanted energy.
WireWorld Matrix 2 6-Way Power Distribution Block and Stratus 7 Power (UK Plug) Stratus7
- Wireworld Stratus 7 Power Cable
- Flat design, 7/8 inch wide x 3/8 inch thick and is very flexible to make installation easier
- Wire Gauge: 12 AWG
- Materials: OFC Oxygen Free Copper conductors
- Insulation: Composilex 2 Insulation reduces interference and greatly improves performance
- Globe-Grip Plug, making life easier for you to remove the power cable from your equipment with ease
- Suitable for use in any application requiring an IEC(C13) connector
- Constructed from OF Copper with brass contacts
- High current handling capabilities
- Lifetime Warranty
john_online_shop
john_online_shop
Number of posts : 35
Registration date : 2017-06-22
Source(s): NAD C568
Amplification: NAD C375BEE
Speakers: Dynaudio DM 2/6
http://bluezircon.lelong.com.my
WireWorld Matrix 2 6-Way Power Distribution Block and Stratus 7 Power (UK Plug) Empty Re: WireWorld Matrix 2 6-Way Power Distribution Block and Stratus 7 Power (UK Plug)
Post by john_online_shop Sat Mar 24, 2018 8:04 pm
BUMP
john_online_shop
john_online_shop
Source(s): NAD C568
