Monitor Audio Bronze 5 5.1 Home Theater System
Monitor Audio Bronze 5 5.1 Home Theater System Brand New. Now Selling At RM9,899. Free Shipping Within West Malaysia.
1 Pair of Monitor Audio Bronze 5 Fronts
1 Pair of Monitor Audio Bronze FX Rears ( White )
1 Monitor Audio Bronze Centre
1 Monitor Audio Bronze W10 Subwoofer.
Purity and precision, Monitor Audio's most democratically priced speaker line has everything to gain from Monitor Audio’s dynamic forty-year design heritage.
Enriched as it is with elements of Platinum, Gold and Silver, the brilliant new Bronze series will transcend the expectations of its price class and eclipse even its venerated multi-award winning predecessor Bronze BX.
The features speak for themselves. For the first time Monitor Audio are using spectacular steel-grey C-CAM driver cones for a seamless blend with finishes, available in a choice of Black Oak, Pearlescent Walnut, Rosemah and a new White Ash.
Invisible driver fixings and floating magnetic grilles add to the impression of streamlined sophistication, lending new Bronze the look and feel of a premium range.
Monitor Audio Bronze Key Features:
New C-CAM gold dome tweeter
Twin 5 1/2" C-CAM bass and mid-range drivers
Single bolt-through driver systems for increased overall bracing, rigidity and driver/baffle de-coupling
HiVe port technology
High quality crossovers with premium grade Polypropylene film capacitors used throughout
Rigid 18mm MDF construction throughout, employing radial and cross-bracing techniques for high rigidity resulting in low cabinet coloration
Floor-level terminal panel for easy termination and neat cable access. Bi-wire/ Bi-amp terminal configuration
Premium quality vinyl veneer finishes
Acoustically matched with all other Bronze speakers for excellent imaging and timbre consistency in surround applications
New C-CAM gold dome tweeter design
5 1/2” bass/mid-range driver with concave ‘dished’ C-CAM cone profile
Optimised for di-pole or bi-pole operation by the simple flick of a switch located on the rear terminal panel
Single bolt-through driver system, for increased overall bracing and rigidity
Dual 5 1/2” bass/midrange drivers with concave ‘dished’ C-CAM cone profile
Acoustically matched to Bronze speaker systems for excellent imaging and consistency of timbre in surround applications
Single bolt-through driver systems, for increased overall bracing, rigidity and driver/baffle de-coupling
Invisible magnetic grille fixing
Ultra long throw 10” driver featuring concave ‘dished’ C-CAM cone
10” flat panel ABR (auxiliary bass driver) mounted on the bottom to augment low frequency extension and power handling
Powerful Class-D Amplifier delivering over 200W with low distortion
Switch Mode power supply, designed to deliver high continuous rating and provides the instantaneous delivery of high current when required
DSP processing with all control features and crossover performed in the digital domain
Three pre-set EQ mode settings (Music, Movie, Impact)
12 volt trigger - provides switching control from AV amp, processor or home automation control system
18mm thick MDF construction
Heavy cabinet bracing applied to provide stiff, low resonance cabinet
System Format
2 1/2 Way
Frequency Response
37Hz - 30kHz
Sensitivity (1W @ 1M)
90dB
Nominal Impedance
8O
Maximum SPL (dBA @1M – each)
113.8dBA (pair)
Power Handling R.M.S.
120W
30-120W
Cabinet Design
Dual chamber bass reflex – Ported front and rear HiVeII Port technology
Crossover Frequency
LF: -6dB @ 600Hz
MF/HF: 2.8kHz
Drive Unit Complement
1 x 5 1/2" C-CAM bass
1 x 5 1/2" C-CAM bass mid-range driver
1 x 25 mm gold dome C-CAM tweeter
Cabinet Dimensions: (H x W x D)
850 x 165 x 248 mm
(33 7/16 x 6 1/2 x 9 3/4 inches)
Complete Dimensions inc grille, terminals, plinths and spikes: (H x W x D)
898 x 215 x 282 mm
(35 5/8 x 8 7/16 x 11 1/8 inches)
Weight (Individual)
11kg (24lbs 6oz)
System Format
2 Way
Frequency Response
60Hz - 30kHz
Nominal Impedance
8O
113dBA
120W
20-120W
Cabinet Design
Sealed Cabinet
2 x 5 1/2" C-CAM bass mid-range driver.
Crossover Frequency
3.0kHz
165 x 460 x 165 mm
6 1/2 x 18 1/8 x 6 1/2 inches
Complete Dimensions inc grilles & terminals: (H x W x D)
165 x 460 x 193 mm
6 1/2 x 18 1/8 x 7 5/8 inches
Weight (Individual)
5.6kg (12lbs 6oz)
System Format
2 Way
Frequency Response
65Hz - 30kHz
88dB
Nominal Impedance
8O
110dBA (pair)
80W
20-80W
Cabinet Design
Sealed Cabinet
1 x 5 1/2" C-CAM bass mid-range driver.
2 x 25 mm gold dome C-CAM tweeter
Crossover Frequency
2.8kHz
274 x 276 x 105 mm
(10 13/16 x 10 7/8 x 4 1/8 inches)
Complete Dimensions inc grilles & bracket: (H x W x D)
274 x 281 x 118 mm
(10 13/16 x 11 1/6 x 4 5/8 inches)
Weight (Individual)
3.2kg (7lbs)
Low Frequency Limit
30Hz
Upper Frequency Limit
40-120Hz (Variable Low Pass filter)
Low Pass Filter Alignment
12dB/ Octave variable + 12dB/ Octave Fixed @ 150Hz
Amplifier Output
220W R.M.S
Amplifier Classification
Class D with Switch mode PSU
1 x 10" C-CAM Long throw subwoofer driver + 1 x 10” flat panel ABR
External Dimensions: (H x W x D)
320 x 320 x 330 mm
12 5/8 x 12 5/8 x 13 inches
(364 x 320 x 364 mm
14 5/16 x 12 5/8 x 14 5/16 inches inc grille amp & feet)
Input Impedance
20kO
Standby power consumption
0.5W (ErP approved)
Mains Input Voltage
220-240Vac - 50-60Hz
Electronic auto-select
Weight
12.9kg (28lb 6oz)
BRANDED led tv
amplifier
speaker
cd player
The Monitor Audio Bronze AV is a complete 5.1 Channel Home Cinema Speaker System comprising:1 Pair of Monitor Audio Bronze 5 Fronts
Monitor Audio Bronze 5 AV Package
Purity and precision, Monitor Audio's most democratically priced speaker line has everything to gain from Monitor Audio’s dynamic forty-year design heritage. Enriched as it is with elements of Platinum, Gold and Silver, the brilliant new Bronze series will transcend the expectations of its price class and eclipse even its venerated multi-award winning predecessor Bronze BX.Purity and precision, Monitor Audio's most democratically priced speaker line has everything to gain from Monitor Audio’s dynamic forty-year design heritage.
- All new C-CAM (Ceramic-Coated Aluminium/Magnesium) driver configurations
- A new 25mm C-CAM Gold Dome tweeter extends each system’s frequency response to an ultra-sonic 30kHz
- New magnetically-fixed ‘floating’ cloth grilles
- Steel-grey C-CAM driver cones
- Black Oak, Pearlescent Walnut, Rosemah and a new White Ash finish
System Format
2 1/2 Way
Frequency Response
37Hz - 30kHz
90dB
Nominal Impedance
8O
113.8dBA (pair)
120W
30-120W
Cabinet Design
Crossover Frequency
LF: -6dB @ 600Hz
MF/HF: 2.8kHz
850 x 165 x 248 mm
898 x 215 x 282 mm
Weight (Individual)
11kg (24lbs 6oz)
System Format
2 Way
Frequency Response
60Hz - 30kHz
Nominal Impedance
8O
113dBA
120W
20-120W
Cabinet Design
Sealed Cabinet
Crossover Frequency
3.0kHz
165 x 460 x 165 mm
165 x 460 x 193 mm
Weight (Individual)
5.6kg (12lbs 6oz)
System Format
2 Way
Frequency Response
65Hz - 30kHz
88dB
Nominal Impedance
8O
110dBA (pair)
80W
20-80W
Cabinet Design
Sealed Cabinet
Crossover Frequency
2.8kHz
274 x 276 x 105 mm
274 x 281 x 118 mm
Weight (Individual)
3.2kg (7lbs)
Low Frequency Limit
30Hz
Amplifier Output
220W R.M.S
320 x 320 x 330 mm
(364 x 320 x 364 mm
Input Impedance
20kO
0.5W (ErP approved)
Mains Input Voltage
Weight
12.9kg (28lb 6oz)
BRANDED led tv
amplifier
speaker
cd player
- Number of posts : 1342
» Monitor Audio Bronze 6 5.1 Home Theater Package
» Monitor Audio Mass 5.1 Home Theater System
» Monitor Audio Mass 2G 5.1 Home Theater System
» WiiM Amp + Monitor Audio Bronze 50 6G Hi-Fi System Package
» Rega io + Monitor Audio Bronze 100 6G Hi-Fi System Package
