Monitor Audio Bronze 6 5.1 Home Theater Package
Monitor Audio Bronze 6 5.1 Home Theater Package Brand New. Now Selling At RM10,699. Free Shipping Within West Malaysia.
Monitor Audio's latest entry-level champion moves up a gear from BX and rival budget speakers because new Bronze is simply in a class of its own. The features speak for themselves. For the first time we're using spectacular steel-grey C-CAM driver cones for a seamless blend with finishes. Invisible driver fixings and floating magnetic grilles add to the impression of streamlined sophistication, lending new Bronze the look and feel of a premium range.
The Bronze 6 AV pack is comprised of
1 pair of Monitor Audio Bronze 6 Fronts
1 Pair of Monitor Audio Bronze FX Rears ( White )
1 Monitor Audio Bronze Centre
1 Monitor Audio Bronze W10 Subwoofer.
New C-CAM gold dome tweeter
Optimised 6 1/2” mid-range driver featuring concave ‘dished’ C-CAM cone profile
Dual 6 1/2” bass drivers featuring concave ‘dished’ C-CAM cone profile
Two and a half way configuration with differentially tuned acoustic system - higher efficiency and improved low frequency extension
HiVe port technology
All drivers feature single bolt-through driver systems, for increased overall bracing, rigidity and driver/baffle de-coupling
High quality crossovers with premium grade Polypropylene film capacitors used throughout
Rigid 18mm MDF construction throughout, employing radial and cross-bracing techniques for high rigidity resulting in low cabinet coloration
Floor-level terminal panel for easy termination and neat cable access. Bi-wire/ Bi-amp terminal configuration
Premium quality vinyl veneer finishes
Dual 5 1/2” bass/midrange drivers with concave ‘dished’ C-CAM cone profile
Acoustically matched to Bronze speaker systems for excellent imaging and consistency of timbre in surround applications
Single bolt-through driver systems, for increased overall bracing, rigidity and driver/baffle de-coupling
Invisible magnetic grille fixing
Acoustically matched with all other Bronze speakers for excellent imaging and timbre consistency in surround applications
New C-CAM gold dome tweeter design
5 1/2” bass/mid-range driver with concave ‘dished’ C-CAM cone profile
Optimised for di-pole or bi-pole operation by the simple flick of a switch located on the rear terminal panel
Single bolt-through driver system, for increased overall bracing and rigidity
Ultra long throw 10” driver featuring concave ‘dished’ C-CAM cone
10” flat panel ABR (auxiliary bass driver) mounted on the bottom to augment low frequency extension and power handling
Powerful Class-D Amplifier delivering over 200W with low distortion
Switch Mode power supply, designed to deliver high continuous rating and provides the instantaneous delivery of high current when required
DSP processing with all control features and crossover performed in the digital domain
Three pre-set EQ mode settings (Music, Movie, Impact)
12 volt trigger - provides switching control from AV amp, processor or home automation control system
18mm thick MDF construction
Heavy cabinet bracing applied to provide stiff, low resonance cabinet
Specification:
System Format 2 1/2 Way
Frequency Response 34Hz-30kHz
Sensitivity (1W @ 1M) 90dB
Nominal Impedance 80
Maximum SPL (dBA @1m - each) 114.8dBA (pair)
Power Handling R.M.S. 150W
Recommended Amplifier Requirements 40-150W
Cabinet Design Bass Section - Front/Rear bass reflex with HiVE II Port technology.
Sealed mid-range enclosure.
Crossover Frequency LF: -6dB @ 150Hz
MF/HF: 2.5kHz
Drive Unit Complement
2 x 6 1/2" C-CAM bass
1 x 6 1/2" C-CAM bass mid-range driver
1 x 25 mm gold dome C-CAM tweeter
Cabinet Dimensions (H x W x D) 985 x 185 x 315 mm
(38 3/4 x 7 5/16 x 12 3/8 inches)
Complete Dimensions inc grille, terminals, plinths and spikes (H x W x D) 1033 x 235 x 350 mm
(40 11/16 x 9 1/4 x 13 3/4 inches)
Weight (Individual) 16.6 kg (36 lbs, 8 oz)
System Format 2 Way
Frequency Response 60Hz - 30kHz
Maximum SPL (dBA @1M – each) 113dBA
Power Handling R.M.S. 120W
Recommended Amplifier Requirements 20-120W
Cabinet Design Sealed Cabinet
Drive Unit Complement 2 x 5 1/2" C-CAM bass mid-range driver.
Crossover Frequency 3.0kHz
Cabinet Dimensions: (H x W x D) 165 x 460 x 165 mm
6 1/2 x 18 1/8 x 6 1/2 inches
Complete Dimensions inc grilles & terminals: (H x W x D) 165 x 460 x 193 mm
6 1/2 x 18 1/8 x 7 5/8 inches
Weight (Individual) 5.6kg (12lbs 6oz)
System Format 2-Way
Frequency Response 65Hz - 30kHz
Sensitivity (1W @ 1M) 88dB
Maximum SPL (dBA @1M – each) 110dBA (pair)
Power Handling R.M.S. 80W
Recommended Amplifier Requirements 20-80W
Drive Unit Complement 1 x 5 1/2" C-CAM bass mid-range driver.
2 x 25 mm gold dome C-CAM tweeter
Crossover Frequency 2.8kHz
Cabinet Dimensions: (H x W x D) 274 x 276 x 105 mm
(10 13/16 x 10 7/8 x 4 1/8 inches)
Complete Dimensions inc grilles & bracket: (H x W x D) 274 x 281 x 118 mm
(10 13/16 x 11 1/6 x 4 5/8 inches)
Weight (Individual) 3.2kg (7lbs)
Low Frequency Limit 30Hz
Upper Frequency Limit 40-120Hz (Variable Low Pass filter)
Low Pass Filter Alignment 12dB/ Octave variable + 12dB/ Octave Fixed @ 150Hz
Amplifier Output 220W R.M.S
Amplifier Classification Class D with Switch mode PSU
Drive Unit Complement 1 x 10" C-CAM Long throw subwoofer driver + 1 x 10” flat panel ABR
External Dimensions: (H x W x D) 320 x 320 x 330 mm
12 5/8 x 12 5/8 x 13 inches
Input Impedance 20kO
Standby Power Consumption 0.5W (ErP approved)
Mains Input Voltage 220-240Vac - 50-60Hz
Weight 12.9kg (28lb 6oz)
BRANDED led tv
amplifier
speaker
cd player
Specification:
MF/HF: 2.5kHz
System Format 2 Way
System Format 2-Way
BRANDED led tv
amplifier
speaker
cd player
- Number of posts : 1318
» Monitor Audio Bronze 5 5.1 Home Theater System
» Monitor Audio Silver 300 5.1 Home Theater Package
» Monitor Audio Silver 200 5.1 Home Theater Package
» Audio Pro home theater package 5.1 (used)
» Onkyo A-9110 + Monitor Audio Bronze 50 6G Hi-Fi System Package
