ONKYO TX-NR1008 9.2-Channel Network A/V Receiver (USED)
Key Features:-
- THX Select2 Plus Certified
- HDMI 1.4a Support for 3D Video and Audio Return Channel
- PC Audio and Internet Radio via Network Function (DLNA)
- ISF Video Calibration for Accurate Video Reproduction
- Audyssey MultEQ/DSX and Dolby Pro Logic IIz
The Easy Way to Enjoy Home Networking and Distributed Audio
The TX-NR1008 is an upper-mid-range A/V powerhouse designed to give you maximum set-up flexibility in the home. Its 9.2 speaker channels let you enjoy a multichannel source in your main room, plus powered audio in two other rooms. Or you can use the extra channels to take full advantage of the new surround dimensions of Audyssey DSX™ and Dolby® Pro Logic® IIz. Other processing highlights include DTS-HD Master Audio™ and Dolby® TrueHD for pristine lossless audio on Blu-ray Disc, and HDMI® upscaling of all video sources to 1080p with Faroudja DCDi Cinema™. As a network A/V receiver compatible with Windows® 7 and DLNA, the TX-NR1008 lets you stream audio from your PC or from internet radio channels such as vTuner and Last.fm. Set up and calibration are easy and accurate, thanks to ISF video calibration, a new overlaid graphical on-screen display, and Audyssey room correction and equalization. Bi-amping capability and a smorgasbord of the latest connections complete what is an outstanding entertainment package.
AMPLIFIER FEATURES
- 180 W/Ch at 6 Ω, 1 kHz, 1 Channel Driven, IEC
- WRAT (Wide Range Amplifier Technology)
- Three-Stage Inverted Darlington Circuitry
- H.C.P.S. (High Current Power Supply) Massive High Power Transformer
- Linear Optimum Gain Volume Circuitry
https://www.eu.onkyo.com/en/products/tx-nr1008-35601.html
Conditions: 7/10 (USED)
Price: RM1350 inclusive postage to West Malaysia
- Number of posts : 5622
» ONKYO TX-NR1008 9.2-Channel Network A/V Receiver (USED)
» Onkyo TX-NR1008 9.2-Channel AV Receiver (Faulty Set) (Sold)
» Onkyo TX-NR 737 7.2 Channel Network AV Receiver (Used)
» Onkyo TX-NR 809 7.2-Channel Network A/V Receiver @ RM400
» ONKYO TX-NR929 9.2-Channel THX Network A/V Receiver
