Peavey PV 2000 professional stereo power amp (Used)SOLD
Peavey PV2000 professional stereo power amp
Features: All American power, proven reliability. The powerful PV 2000 carries the tradition of Peavey value engineering one step further by building a dedicated (150 Hz) subwoofer crossover and 50 Hz low-cut filter into each channel.
TRS 1/4 inch input jac
Mode switch for stereo or bridge operation
Low-cut filter switch for 40 Hz low cut filter
Built-in crossover with 150 Hz switch
Thru/low output jacks and high output jacks
LED indicators for input signal, DDT & power
Peavey's famous DDT compression system
Stereo Mode: 2 Ohms: 1000* Watts RMS x 2
Stereo Mode: 4 Ohms: 700 Watts RMS x 2
Stereo Mode: 8 Ohms: 400 Watts RMS x 2
Bridge Mode-Mono: 4 Ohms: 2000* Watts RMS
Bridge Mode-Mono: 8 Ohms: 1400 Watts RMS
Rated Output Power: 4 Ohms: 0.1% THD: 625 Watts RMS
Rated Output Power: 8 Ohms: 0.1% THD: 370 Watts RMS
Total Harmonic Distortion: Less than 0.07% 20 Hz to 20 K at rated power, 4 Ohms
Frequency Response: 20 Hz to 20 kHz
Damping Factor: greater than 300
Hum and Noise: 100 dB
Rack Spaces: 4 RU
*Not recommended for continuous 2 ohm stereo/4 ohm bridge duty.
Dimensions:
Unpacked Weight: 63.6 lbs
Condition : 7/10
Price : 1200.00 nego
Contact : loy 0163683523
Rack Spaces: 4 RU
Dimensions:
Condition : 7/10
- Number of posts : 4064
» (not available) Peavey CS-200X stereo power amp
» Vintage Luxman M-2000 Stereo 180watts Power Amplifier ( Sold)
» Maingo professional stereo power amplifier.
» BGW 750G Stereo 375 watts per channel Professional Power Amplifier XLR input
» Vestax PDX-2000 Professional Direct Drive Turntable
