Raphaelite MAS 100 Pre-Amplifier
Raphaelite MAS 100 is one of the high end pre amplifier in Raphaelite’s Professional series. This pre amp uses Raphaelite’s in-house designed vacuum tube (12AU7 / ECC82) pre-amplification, combined with low impedance op-amp output circuit. There are 2 selectable output options which is either via transformer or op-amp. With transformer output being selected , the output phase can be switched and lower gained (-6dB) can be selected for low volume listening.
For protection to the power amplifier & speakers, the pre-amp is equipped with muting relay circuit to prevent occurrence of popping. The unit have comprehensive inlet & outlet selection, balanced outlet enable connectivity with professional equipment. Equipped with multiple set of linear power supply.
The high voltage and voltage stabilization is executed with vacuum tube. The high precision power supply circuit enable high reliability, accurate & low noise power supply.
High precision machining & multiple shielding aluminum casing enable the unit to have high gain with low noise output. At the same time having a robust and presentable look.
Price - RM9,500.00
Warranty - 1 yr local warranty
Contact - Terence, 0176028532
Price - RM9,500.00
» Raphaelite DP34 II Integrated Tube Amplifier For LS3/5A (New)
» Raphaelite CSM 05 single ended monobloc amplifier
» Raphaelite MAS300 Phonostage (MM/MC)
» Raphaelite DP34 Push-Pull Valve Integrated Amplifier
» Raphaelite CP6V Push-Pull Valve Integrated Amplifier
