Yaqin MS-845 Pre-Amplifier + Tube Mono Block Power Amplifier
![Yaqin MS-845 Pre-Amplifier + Tube Mono Block Power Amplifier I-yaqi10](https://i.servimg.com/u/f53/20/31/30/47/i-yaqi10.jpg)
![Yaqin MS-845 Pre-Amplifier + Tube Mono Block Power Amplifier 16092710](https://i.servimg.com/u/f53/20/31/30/47/16092710.jpg)
FEATURES :
preamp and power amp is a sub-structure, reasonable layout, lower noise.Before the class is “SRPP” circuit, and increase the cathode output device, wide frequency response, low output impedance.
After amplification for low-level resistance of the power transistor (845), and A single-ended amplifier, the sound quality is good.
After the circuit level to promote the “SRPP” circuit, and for the dual parallel, wide frequency response, pushing strong.
Japan imported the audio output transformer using dedicated oriented silicon steel Z11 (0.35mm thick) and oxygen-free high strength enameled wire and special winding process multi-group production, so that the machine wide frequency response, to ensure that the machine high, medium and low frequency sounds good , transparent and powerful.
This machine adopts foreign name Factory sound dedicated enthusiast and non-polarized electrolytic (MKP) Need for high-quality imported French Suren gold blocking capacitors and manufacturing, the main audio channel dedicated to use imported from Japan (ALPS) volume motor potentiometer, with quiet background music, low noise, no sound pollution and durable.
High-voltage power supply for the automatic delay control, can effectively extend the tube life, and with remote control function.
Electrical Specifications
Output Power: 25W + 25W (8Ω)Distortion: ≤ 2.5% (1kHz)
Frequency response: 10Hz – 40kHz (-2dB)
SNR: ≥ 86dB (A)
Input Sensitivity: ≤ 0.2V
Load Impedance: 4Ω – 8Ω
Tubes: preamp: 12AX7 × 2 12AU7 × 1
power amp : 12AU7 × 2 845 × 1
Power Voltage: AC110V/220V 60Hz/50Hz (110V ,120V,230V,240V,version will take 3-14 work days to order). 220v is in stock.
Volume: preamp: 275mm x 195mm x 390mm (D x W x H)
power amp: 315mm x 395mm x 435mm (D x W x H)
Gross weight: preamp: 11kg
Powe amp: 28kg x2 (a pair) = 56 kg
18 months warranty
New in box
Price: RM15,899
- Number of posts : 1404
» Yaqin MS-845 Mono Block Power Amplifier (1pair)
» Jolida JD 3000A tube mono block power amplifier
» Gryphon DM100 dual mono Power amplifier , Tice Power Block Titan(2pcs) Power Conditional, Marant CD SA14 SACD Player, Cary DAC 200TS Tube DAC
» TRI 300B Mono Block Vacuum Tube Amplifier & Preamp (Sold)
» Marantz MA500 Mono Block Power Amplifier - 4 pcs available
