SANSUI AU-alpha 907i stereo Integrated Amplifier (100v )sold
The stereo Integrated Amplifier which adopted the alpha-X balance circuit
Form Alpha-X balance integrated amplifier
Output power (20Hz - 20kHz)
Both channel drive 190W+190W (6ohm)
160W+160W (8ohm)
THD (at the time of an effective output) 0.003% or less (8ohm)
Cross modulation distortion (at the time of an effective output) 0.003% or less (8ohm)
Dumping factor 150 (8ohm)
Frequency characteristic (1W) DC-300kHz+0 -3dB
Input sensitivity/impedance Balance, Normal:1V/3kohm (1kHz)
SN ratio (A network) 120dB or more
TIM distortion (SAWTOOTH) Below a limit-of-measurement value
Slew rate �}200v/microsec (6ohm)
Rise time 0.5microsec
(1kHz) Phono man month: 2.5mV / 47kohm
Phono MC: 300 microvolts/100 ohm
compact disk, Tuner, Line, Prosessor, Tape/DAT/Play1-2-3:150mV /, 47kohm
Phono maximum permissible input
(THD 0.01%) MM:250mV
MC:25mV
Frequency characteristic Phono man month: 20Hz-20kHz�}0.2dB
compact disk, Line, and Tape/DAT/Play1-2-3:DC-300kHz+0 -3 dB
SN ratio Phono man month: 90dB or more
Phono MC: 75dB or more
Tuner, Line, compact disk, and more than Tape/DAT/Play1-2-3:110dB
Tone control The Bass maximum variation: �}5dB (50Hz)
The Treble maximum variation: �}5dB (15kHz)
Turnover frequency: 75Hz, 150Hz
Subsonic Filter 16Hz (-3dB), 6dB / oct
Loudness 50Hz:+6dB
10kHz:+4dB
Power dissipation 400W
Dimensions Width 448x height 160x depth of 441mm
Weight 28.0kg
made japan
price sold
contact loy 0163683523
- Number of posts : 4005
» Arcam Alpha 5 PLUS British Stereo Integrated Amplifier ( Sold )
» SOLD Sansui AU-717 Stereo Integrated Amplifier
» Sansui A-60 Stereo Integrated Amplifier (Sold)
» Sansui Stereo Integrated Amplifier (sold)
» Arcam Alpha 6 British Stereo Integrated Amplifier With Phono and Remote (Sold)
