Denon AVC-6500H AV Receiver(sold)
Channels | 11.2 channels |
Power | 140 W per channel (8 ohm, 20 Hz - 20 kHz, 0.05% 2ch drive) |
Audio Formats | Dolby Atmos, DTS:X, Auro-3D, IMAX Enhanced |
Up-mixing Audio Formats | Dolby Surround, DTS Neural:X |
Virtual Audio Formats | DTS Virtual:X |
High Resolution Audio Support | - ALAC : up to 192 kHz / 24-bit - FLAC : up to 192 kHz / 24-bit - WAV : up to 192 kHz / 24-bit - DSD: up to 5.6 MHz |
Internal Hardware | - 11 powerful amplifiers in a monolithic design - Low impedance drivers - Four 4th generation 300MHz SHARC DSP processors - AKM 32-bit D/A converters |
Audio Calibration System | Audyssey MultEQ XT32, Audyssey Dynamic Volume, Audyssey Dynamic EQ, LFC and SubEQ HT |
Streaming Services | Spotify Connect, Pandora, SiriusXM, Amazon Music, TIDAL, Deezer, iHeart Radio, Napster, Soundcloud, Mood Mix - HEOS/AirPlay 2 support |
Connectivity | Built-in WiFi (2.4GHz/5GHz), Bluetooth 3.0 + EDR, Ethernet port |
Ports | HDMI : 8 inputs (7 rear, 1 front) / 3 outputs (rear) [HDCP 2.2, eARC support] USB : 1 (1 front) [v 2.0] Composite : 4 inputs (rear), 2 outputs (rear) Component : 2 inputs (rear), 1 output (rear) Analogue : 6 inputs (rear) Phono : 1 input (rear) Digital Inputs : 2 coaxial (rear), 2 optical (rear) Multi-room outputs : 2 analogue (rear) Multichannel pre-outs : Yes (11.2 channels) Subwoofer outputs : 2 Multichannel inputs : No Various : Ethernet port, Denon Link HD, Remote control input, Remote control output, 2 x 12V triggers, RS-232C port, FM/AM Antenna ports |
HDMI Features | 4K Ultra HD 60Hz video, 4:4:4 Pure Color sub sampling, Dolby Vision, High Dynamic Range (HDR10), Hybrid Log-Gamma (HLG), eARC (enabled via firmware update) 21:9 video, 3D and BT.2020 passthrough |
Multi-room Features | HEOS technology, AirPlay 2 |
Voice Control | Amazon Alexa, Google Assistant, Apple Siri, Josh.ai |
Custom Integration | IHIJI Invision, Domotz Pro, Control4, Crestron intelligence |
User Experience | Remote app, Setup Assistant, IP Control |
Extra Features | Analogue to HDMI scaling, HDMI to HDMI scaling, HDMI-CEC, Bi-Amp, 2 Multi-room zones, ECO mode |
Dimensions (W x D x H) | (maximum) : 17.1 x 6.6 x 15.1 inch / 434 x 389 x 167 mm |
Weight | 31.1 lbs / 14.6 kg |
CONDITION:8/10
PRICE: sold
FOR MORE INFO ,PLEASE CALL OR WHATAPPS:
018-9742567 YANG
016-5368723 YUAN
YUAN- Frequent Contributor
- Number of posts : 135
» Denon AVC-X 6500H AV Receiver (Sold)
» Denon Avc-X 6500H 11.2 Ch (sold)
» Denon AV Receiver 1909 & Denon iPod Dock ASD-11R (SOLD)
» Denon AVR-3805 AV receiver SOLD
» Denon AVC-X4700H 9.2ch 8K AV Receiver (Sold)
