Cambridge Audio AXA35 Integrated Amplifier + AXC35 CD Player + AXN10 Network Player
Cambridge Audio AXA35 Integrated Amplifier + AXC35 CD Player + AXN10 Network Player Brand New. Now Selling At RM7,599. Free Shipping Within West Malaysia.
012-2732555 Hew
016-3098668 John
017-2349074 Rick
012-2536225 Peter
012-2309169 Chris
MONDAY - 10AM-6PM
TUESDAY - 10AM-6PM
THURSDAY - 10AM-6PM
FRIDAY - 10AM-6PM
SATURDAY - 10AM-6PM
POWER OUTPUT 35 Watts (into 8 Ohms)
THD (UNWEIGHTED) <0.01% @ 1kHz, 80% of rated power <0.15% 20Hz - 20kHz, 80% of rated power
FREQUENCY RESPONSE (-3DB) 5Hz - 50kHz
S/N RATIO (REF 1W) >82dB (unweighted)
INPUT IMPEDANCES 47k ohms
POWER AMP DAMPING FACTOR > 50
MAX. POWER CONSUMPTION 260W
BASS/TREBLE CONTROLS Shelving, ultimate boost/cut +/- 10dB @ 100Hz and 10kHz
STANDBY POWER CONSUMPTION <0.5W
INPUTS 4x RCA, 1x Phono, 1 x 3.5mm Aux input (front panel)
OUTPUTS Speakers, Rec Out, USB 5V power
DIMENSIONS (HXWXD) 83 x 430 x 335mm (3.3 x 16.9 x 13.2”)
WEIGHT 5.6kg (12.3lbs)
Audio AXC35
THD @ 1KHZ -10DBFS <0.01%
D/A CONVERTOR Wolfson Microelectronics WM8524
GAPLESS PLAYBACK Yes
FILTER 2 -pole Butterworth filter
FREQUENCY RESPONSE (+/-0.4DB) 20Hz - 20kHz
THD @ 1KHZ 0DBFS <0.006%
S/N RATIO, A WEIGHTED >95dB
CROSSTALK @1KHZ <-98dB
CROSSTALK @20KHZ <-95dB
OUTPUT IMPEDANCE <50 ohms
MAXIMUM POWER CONSUMPTION 15W
DIMENSIONS 75 x 430 x 305mm (3.0 x 16.9 x 12.2”)
WEIGHT 4.3kg (9.5lbs)
S/PDIF OUTPUT IMPEDANCE <75 ohms
Cambridge Audio AXN10
INPUTS Ethernet, USB socket (mass storage), Wi-Fi, Bluetooth
OUTPUTS Line out (unbalanced), Digital out (Coax and Optical)
DAC ESS Sabre ES9033Q
FREQUENCY RESPONSE 20Hz – 70kHz +0/-1dB
ETHERNET IEEE 802.3 10 Base-T or 100 Base-T
WI-FI Wi-Fi 5 dual band 2.4/5gHz
BLUETOOTH 5.0 A2DP/AVRCP supporting SBC and AAC
COMPATIBILITY UPnP, Local USB media, Internet Radio, Chromecast, Spotify connect, Tidal, Qobuz, Roon Ready, Airplay 2
AUDIO FORMATS ALAC, WAV, FLAC, AIFF, DSD (x512), WMA, MP3, AAC, HE AAC, AAC+, OGG Vorbis
HI-RES SUPPORT Up to 768KHz 32bit PCM, up to DSD512
MAX POWER CONSUMPTION 20W
DIMENSIONS (W X H X D) 430 x 75 x 305mm
WEIGHT 3.3kg
AXA35
Integrated Stereo Amplifier with (Built-in) Phono-Stage- 35 Watts Power per Channel – for detailed performance at all volumes, ideal for smaller/medium sized rooms
- Built-In Phono Stage – to plug & play a vinyl turntable
- Slim Timeless Design – classic hi-fi size, with Lunar Grey aluminium trim
- Tone Controls – fine-tune sound to compensate for room dynamics
- Digital Display – white LED, clearly shows; source, volume & menus
- Headphone Socket – full size socket for high-quality after-hours listening
- Front Aux Input – 3.5mm socket to easily connect compatible devices
Your Journey into Sound
AXA35 is the ideal amp to begin listening to music and really appreciating it – hearing detail in familiar tunes you’ve previously missed. That’s down to the toroidal transformer it uses, a tech found higher up our range. Choose a pair of speakers to suit your taste, perhaps they’ve been in the family for years or maybe something from our SX Series.Release the Wheels of Steel
The built-in phono stage is the ace up AXA35’s sleeve. It means that you can plug a turntable straight in without any extra kit. Moving magnet (MM) compatibility means AXA35 works with a wide variety of turntables – including that vintage one you’ve had your eye on. Soon you’ll be playing the records you’ve been saving for, and planning what to buy next.Setting the Tone
With separate bass and treble controls, you can fine-tune AXA35’s sound to suit your taste, speakers and room dynamics. The volume level is shown on the LED dot matrix display, and with 35 watts per channel you’ll have plenty of kick for smaller to medium sized rooms.Wired for Sound
AXA35 is a well-connected amp, with no less than 4 pairs of RCA inputs, plus a pair of phono sockets for a turntable and a pair of recording outputs. There’s a rear USB socket for technical upgrades. Hi-fi quality speaker binding posts (connectors), compatible for banana plugs, mean that thick cable connects securely for an authentic sound.Designed for Life
As with the rest of AX Series, AXA35 shares our house-style of Lunar Grey minimalist fascia, black steel cabinet and ‘floating’ base. This timeless look enables an upgrade path through our range. A slim build, in the classic 430mm hi-fi width, also means that AXA35 can easily slot, and breathe new life, into a much-loved system.AXC35
CD Player- Gapless Playback – ideal for classical pieces, live albums & DJ mixes
- High-Quality Wolfson DAC – ensures the digital information from the disc is retrieved accurately
- Digital Coax Out – for pure digital connection to compatible amps
- Slim elegant design – classic hi-fi design, floating effect wedge front foot, lunar grey finish
- Digital display – classy white LED, clear visible information
CD Sound Comes First
AXC35 is an elegant, gapless playback CD player featuring a high-quality digital to analogue converter (DAC). The integrated Wolfson DAC helps accurately retrieve digital information from your discs, to be output to your chosen amplifier – helping to breathe new life into your CD collection. A digital coax out gives you alternative output options.Spinning Songs
You’ve spent years collecting CDs, so why wouldn’t you want to play them for many more years to come? AXC35 is a CD player that will work with any amplifier or system. It’s even got a digital coax out for a straight digital connection to a compatible amp like our AXR100 or a DAC.Complete Control
AXC35 comes with a remote control, so you can choose exactly what to listen to. Compatibility of AX Series remotes means that you only need one device handy for key commands. Alternatively, you can use the controls on the front of AXC35 to skip tracks and so on.Designed for Life
As with the rest of the AX Series, AXC35 shares our house-style of Lunar Grey minimalist fascia, black steel cabinet and ‘floating’ base. This timeless look allows for an upgrade path through our range. A slim build, in the classic 430mm hi-fi width, also means that AXC35 can easily slot, and breathe new life, into a much-loved system.AXN10
Network Player- StreamMagic Gen 4 Module – swift playback & high quality sound
- ESS SABRE ES9033Q DAC – for the latest streaming capabilities
- High-quality Internet Radio – thanks to MPEG-DASH support
- Spotify Connect, TIDAL & Qobuz built in – for the best possible sound
- Roon Ready – easy browsing of your digital music
- Connectivity Choice – with USB playback, RCA/phono, coax & optical or wirelessly with Chromecast built-in, AirPlay 2 & Bluetooth 5.
- Slim elegant design – classic hi-fi width, to fit your system
Choice Comes First
Our new AXN10 network player can breathe new life into your system – opening up the world of Hi-Res music for you. It slots seamlessly into an AX system, taking you beyond your prized collection of discs. There are stacks of free services, like internet radio, as well as the well-known premium ones – many offer free trials. Thanks to our streaming know-how, you’ll be able to enjoy high-quality music easily from a variety of sources via our app.Over a Decade of Streaming Know-How
AXN10 runs off of our latest StreamMagic Gen 4 module and software. It’s a system that we developed ourselves in London for no-compromise, rock-solid, hi-fi music streaming. It’s intuitive to use and is capable of playing music with incredible clarity – up to both 768KHz 32bit PCM and DSD512 (it’s all you’ll need!).Ready for the Revolution?
The convenience of streamed music was once let down by its sound quality, and accessibility. That’s no longer the case, thanks to faster broadband speeds, better CODECs, a wider choice of service, and now because AXN10 brings our acclaimed StreamMagic streaming platform within reach of many more people.Whatever you Want
AXN10 can access free and subscription hi-res streaming services, like internet radio, Spotify Connect, Tidal, Qobuz and Deezer all built-in for best sound quality. With Apple Airplay2 and Chromecast built-in, you can access Apple Music, BBC Sounds and more. AXN10 is also Roon Ready, so can consolidate your digital music listening, regardless of source, into a single magazine-style service.Internet Radio, Live Transmission
It’s just like radio, only it comes via the internet rather than by airwaves. You can listen to your existing favourite broadcast stations, specialist internet only ones (like Soho Radio and NTS), alongside many more from around the world – all free. Who knows what that indie show from New Zealand has instore for you? Plus many stations are at a quality way beyond digital radio.Made for Sharing
If a friend pops round, who’s not got the StreamMagic app, they can share their latest tunes with you, via Bluetooth. Alternatively, if they have some exclusive hi-res FLAC files on USB stick, you can listen together on your hi-fi system simply by plugging the drive into AXN10’s rear USB port.Space Man
One of the challenges of being a music fan can be where to store your collection – another’s the price some of those re-mastered limited editions, with a handful of ‘must-have’ tracks. With AXN10 you can get the best of both worlds: hear the music in incredible hi-res quality, and have no worries about where to squeeze the box-set in.Complete Control
Interacting with AXN10 couldn’t be easier. Our StreamMagic app allows intuitive control of all connected sources – to curate playlists, set presets or browse albums conveniently from your mobile or tablet. Alternatively, there’s a handful of neat buttons on AXN10’s sleek fascia to give direct access to your favourite playlists or internet radio stations.Wired for Sound
Spin AXN10 around and you’ll notice the neat, upside-down writing over the terminals – this makes it easy when leaning over to connect it up to your amp. There’s analogue RCA phono out, digital coax and optical out, USB in, plus a pair of wi-fi antenna for your network – or a LAN cable input if you prefer.Designed for Life
Like the rest of AX Series, AXN10 shares our house-style of Lunar Grey minimalist aluminium fascia, black steel cabinet and ‘floating’ base to create a sleek timeless look. In the classic 430mm hi-fi width AXN10 can slot easily, and breathe new life, into an AX system. Thanks to over-air updates, AXN10 will also be streaming for many years to come.Interested please feel free to contact:
012-2732555 Hew
016-3098668 John
017-2349074 Rick
012-2536225 Peter
012-2309169 Chris
MONDAY - 10AM-6PM
TUESDAY - 10AM-6PM
THURSDAY - 10AM-6PM
FRIDAY - 10AM-6PM
SATURDAY - 10AM-6PM
Audio AXC35
WEIGHT 3.3kg
- Number of posts : 1323
» Cambridge Audio AXA35 Integrated Amplifier + AXN10 Network Player
» Cambridge Audio AXA35 Integrated Amplifier + AXC35 CD Player
» Cambridge Audio AXA25 Integrated Amplifier + AXC25 CD Player + MXN10 Network Player
» cambridge audio axc35 cd player
