Cambridge Audio AXA25 Integrated Amplifier + AXC25 CD Player + MXN10 Network Player
Cambridge Audio AXA25 Integrated Amplifier + AXC25 CD Player + MXN10 Network Player Brand New. Now Selling At RM5,979. Free Shipping Within West Malaysia.
The analogue and digital outs also work simultaneously, meaning your hi-fi can also play nicely as a source in a multiroom set-up.
012-2732555 Hew
016-3098668 John
017-2349074 Rick
012-2536225 Peter
012-2309169 Chris
MONDAY - 10AM-6PM
TUESDAY - 10AM-6PM
THURSDAY - 10AM-6PM
FRIDAY - 10AM-6PM
SATURDAY - 10AM-6PM
POWER OUTPUT 25 Watts (into 8 Ohms)
THD (UNWEIGHTED) <0.015% @ 1kHz, 80% of rated power <0.15% 20Hz – 20kHz, 80% of rated power <0.1% 20Hz – 20kHz @ 10W
FREQUENCY RESPONSE (-3DB) (-3dB) 10Hz - 30kHz
S/N RATIO (REF 1W) >82dB (unweighted)
INPUT IMPEDANCES 32k ohms
POWER AMP DAMPING FACTOR > 100
MAX. POWER CONSUMPTION 180W
BASS/TREBLE CONTROLS Shelving, ultimate boost/cut +/- 5.5dB @ 20Hz and 20kHz
STANDBY POWER CONSUMPTION <0.5W
INPUTS 4x RCA, 1 x 3.5mm Aux input (front panel)
OUTPUTS Speakers, Rec Out, USB 5V power
DIMENSIONS (HXWXD) 83 x 430 x 340mm (3.3 x 16.9 x 13.4”)
WEIGHT 5.1kg (11.2lbs)
Cambridge Audio AXC25
THD @ 1KHZ -10DBFS <0.015%
D/A CONVERTOR Wolfson Microelectronics WM8524
GAPLESS PLAYBACK Yes
FILTER 2 -pole Butterworth filter
FREQUENCY RESPONSE (+/-0.4DB) 20Hz - 20kHz
THD @ 1KHZ 0DBFS <0.006%
S/N RATIO, A WEIGHTED >93dB
CROSSTALK @1KHZ <-95dB
CROSSTALK @20KHZ <-95dB
OUTPUT IMPEDANCE <50 ohms
MAXIMUM POWER CONSUMPTION 15W
DIMENSIONS 75 x 430 x 305mm (3.0 x 16.9 x 12.2”)
WEIGHT 4.3kg (9.5lbs)
Cambridge Audio MXN10
INPUTS Ethernet, USB socket (mass storage), Wi-Fi, Bluetooth
OUTPUTS Line out (unbalanced), Digital out (Coax and Optical)
DAC ESS Sabre ES9033Q
FREQUENCY RESPONSE 20Hz – 70kHz +0/-1dB
ETHERNET IEEE 802.3 10 Base-T or 100 Base-T
WI-FI Wi-Fi 5 dual band 2.4/5gHz
BLUETOOTH 5.0 A2DP/AVRCP supporting SBC and AAC
COMPATIBILITY UPnP, Local USB media, Internet Radio, Chromecast, Spotify connect, Tidal, Qobuz, Roon Ready, Airplay 2
AUDIO FORMATS ALAC, WAV, FLAC, AIFF, DSD (x512), WMA, MP3, AAC, HE AAC, AAC+, OGG Vorbis
HI-RES SUPPORT Up to 768KHz 32bit PCM, up to DSD512
MAX POWER CONSUMPTION 20W
DIMENSIONS (W X H X D) 215 x 52 x 191mm
WEIGHT 1.2kg
BOX CONTENTS MXN10 player, WiFi/BT Antenna (x2), Safety Guide, Quick start guide, Regional mains lead
AXA25
Integrated Stereo Amplifier- 25 Watts Power per Channel – performance at all volumes, ideal for smaller rooms
- Slim Timeless Design – classic hi-fi width, with Lunar Grey aluminium trim
- Tone & Balance Controls – fine-tune sound to compensate for room dynamics
- Front Aux Input – 3.5mm socket to easily connect compatible devices
Sound Comes First
AXA25 is an integrated amplifier built in a classic, fuss-free style. Its slim symmetrical design offers great value and functionality for those looking for a straight-forward solution. A 3.5mm aux input on the front face makes connecting compatible devices a doddle. While four pairs of analogue RCA inputs on the rear mean AXA25’s pretty versatile too.Your Journey into Sound
AXA25 is an amp that lets you listen to music and appreciate how it’s been recorded. You’ll hear detail in familiar tunes that’s previously passed you by. It’s because hi-fi amps, like AXA25, are designed to take a signal from a source (like a CD player), amplify it and then output it to your choice of speakers.Setting the Tone
With separate bass and treble controls, you can fine-tune AXA25’s sound to suit your taste, speakers, and the dynamics of smaller sized rooms. The centrally located volume dial, gives you finger-tip control over the 25 watts per channel of power at your disposal.Wired for Sound
AXA25 has no less than 4 pairs of RCA inputs, a pair of recording outputs and a rear USB socket for technical upgrades. While hi-fi quality speaker binding posts (connectors) mean that thick cable connects securely for an authentic sound – you can even use banana plugs, should you wish.Designed for Life
As with the rest of the AX Series, AXA25 shares our house-style of Lunar Grey minimalist fascia, black steel cabinet and ‘floating’ base. This timeless look allows for an upgrade path through our range. A slim build, in the classic 430mm hi-fi width, also means that AXA25 can easily slot into a much-loved system.AXC25
CD Player- Gapless Playback – ideal for classical pieces, live albums & DJ mixes
- High-Quality Wolfson DAC – ensures the digital information from the disc is retrieved accurately
- Slim elegant design – classic hi-fi design, floating effect wedge front foot, lunar grey finish
- Digital display – classy white LED, clear visible information
CD Sound Comes First
AXC25 is an elegant, gapless playback CD player featuring a high quality digital to analogue converter (DAC). The integrated Wolfson DAC helps accurately retrieve digital information from your discs, to be output to your chosen amplifier – helping to breathe new life into your CD collection. The slim, standard hi-fi component width, player will slip unobtrusively into an existing setup.Spinning Songs
You’ve spent years collecting CDs, so why wouldn’t you want to play them for many more years to come? AXC25 is a stylish slim CD player that will work with any amplifier or system.Complete Control
AXC25 comes with a remote control, so you can choose exactly what to listen to. Compatibility of AX Series remotes means that you only need one device handy for key commands. Alternatively, you can use the controls on the front of AXC25 to skip tracks and so on.Designed for Life
As with the rest of the AX Series, AXC25 shares our house-style of Lunar Grey minimalist fascia, black steel cabinet and ‘floating’ base. This timeless look allows for an upgrade path through our range. A slim build, in the classic 430mm hi-fi width, also means that AXC25 can easily slot, and breathe new life, into a much-loved system.MXN10
Network Player- StreamMagic Gen 4 Module – fast music retrieval & high-quality sound
- ESS SABRE ES9033Q DAC – for the latest streaming capabilities
- High-quality Internet Radio – using MPEG-DASH support
- Spotify Connect, TIDAL & Qobuz built in – for best possible sound
- Roon Ready – simple consolidated browsing of digital music sources
- Connectivity Choice – USB playback, Bluetooth 5.0, Airplay 2 & Chromecast built-in
- Choice of Output – RCA/phono plus, digital coax & optical connections
- Compact, Half Width Footprint – for flexible placement
Compact Size, Massive Choice
Our MXN10 network player can bring the world of Hi-Res music to much-loved hi-fi set-ups and other audio systems. Its half-width compact footprint offers flexibility of placement. MXN10 can access free music, including internet radio, as well as subscription services – many of which offer free trials, so you’ll soon find your perfect streaming partner. MXN10 can play Hi-Res music from USB and NAS drives too. That’s digital music from limitless sources routed through one compact unit – all conveniently controlled with our StreamMagic app from your mobile.The Revolution Will be Streamed
Streamed music once traded-off hi-fi sound quality with convenience. Thankfully, things have changed – thanks to faster broadband speeds, newer audio CODECs, many more services to choose from and now, because MXN10 takes our celebrated StreamMagic platform and makes it available to even more people.Choose More Choice
MXN10 can access both subscription and free Hi-Res streaming services, including internet radio, Spotify Connect, Tidal, Deezer and Qobuz – all integrated for best possible sound quality. With Apple Airplay2 and Chromecast built-in as well, you can access Apple Music and more, including BBC Sounds. And because MXN10 is Roon Ready, you can collate your digital music listening, regardless of origin, into a single magazine-style service.Internet Radio, Live Transmission
Just like traditional radio, only it arrives via the internet rather than the airwaves. You can listen to your favourite broadcast stations, specialist internet only channels (including Soho Radio and NTS), plus many more from around the globe – all for free. Who knows what discoveries you’ll make on that specialist station from Tasmania? Plus, many stations are at a quality much higher than DAB.A Decade of Streaming Distilled
Our latest StreamMagic Gen 4 module and software powers MXN10. It’s a system we developed in London ourselves for no-compromise hi-fi sound and rock-solid streaming performance. It’s intuitive to use and can playback music with up to an incredible 768KHz 32bit PCM or DSD512 resolution – to keep the most demanding listener happy.The Gift of Music
If a friend visits, who doesn’t use the StreamMagic app (yet), they can play their favourite tracks wirelessly from their mobile with Bluetooth. Also, if they’ve any Hi-Res FLAC files on a USB drive, you can both listen in full hi-fi quality, just by inserting the drive into MXN10’s USB port.Crowded House?
There comes a time for us music fans when storage space becomes a problem. Then there’s the price you’ve got to pay to hear a handful of ‘previously unreleased’ tracks exclusive to bulky limited-edition box-sets. The compact MXN10 gives you the best of both worlds: hear the songs in incredible hi-res quality, without the worry of the impact on your shelves, or wallet.Set the Controls
Using MXN10 couldn’t be easier. Our StreamMagic app gives intuitive control of connected sources – to set presets, browse albums or curate playlists, all conveniently from your mobile device. Alternatively, there’s a row of neat buttons on MXN10’s sleek fascia that you can program for direct access to internet radio stations and favourite playlists.Get Connected
Turn MXN10 around to see a pair of analogue RCA phono outs, digital coax and optical out, USB in, a pair of wi-fi antenna sockets for wireless network connection – or a LAN cable input if you prefer.The analogue and digital outs also work simultaneously, meaning your hi-fi can also play nicely as a source in a multiroom set-up.
Desktop Dream Team
As well as its ability to upgrade older kit, MXN10’s perfect for creating a new desktop system alongside our DacMagic 200M – just add a pair of headphones or active speakers. These half-width hi-fi heroes share the same minimalist family look, and now come in a choice of special edition black or lunar grey finish – to complement your study or home office.Designed for Life
MXN10 gets its sleek timeless looks from our signature Lunar Grey aluminium fascia and black ‘floating’ base. The 215mm half-width steel cabinet matches our DacMagic200M and Alva Duo, it offers flexibility of placement and breathes new life into any hi-fi set-up – including that old amp in storage. Thanks to over-the-air updates, MXN10 will be a crowd-pleaser for many years to come.Interested please feel free to contact:
012-2732555 Hew
016-3098668 John
017-2349074 Rick
012-2536225 Peter
012-2309169 Chris
MONDAY - 10AM-6PM
TUESDAY - 10AM-6PM
THURSDAY - 10AM-6PM
FRIDAY - 10AM-6PM
SATURDAY - 10AM-6PM
WEIGHT 1.2kg
- Number of posts : 1323
» Cambridge Audio AXA25 Integrated Amplifier + MXN10 Network Player
» Cambridge Audio AXA25 Integrated Amplifier + AXC25 CD Player
» Cambridge Audio AXC25 & AXA25
» Cambridge Audio AXA35 Integrated Amplifier + AXC35 CD Player + AXN10 Network Player
