Cambridge Audio AXA25 Integrated Amplifier + AXC25 CD Player
Cambridge Audio AXA25 Integrated Amplifier + AXC25 CD Player Empty Cambridge Audio AXA25 Integrated Amplifier + AXC25 CD Player
Post by stylelaser.com.my Sat Apr 20, 2024 12:50 pm
Cambridge Audio AXA25 Integrated Amplifier + AXC25 CD Player Brand NewNow Selling At RM3,599. Free Shipping Within West Malaysia.
Cambridge Audio AXA25 Integrated Amplifier + AXC25 CD Player Axa25_10
AXA25
Integrated Stereo Amplifier
  • 25 Watts Power per Channel – performance at all volumes, ideal for smaller rooms
  • Slim Timeless Design – classic hi-fi width, with Lunar Grey aluminium trim
  • Tone & Balance Controls – fine-tune sound to compensate for room dynamics
  • Front Aux Input – 3.5mm socket to easily connect compatible devices
Sound Comes First
AXA25 is an integrated amplifier built in a classic, fuss-free style. Its slim symmetrical design offers great value and functionality for those looking for a straight-forward solution. A 3.5mm aux input on the front face makes connecting compatible devices a doddle. While four pairs of analogue RCA inputs on the rear mean AXA25’s pretty versatile too.
Your Journey into Sound
AXA25 is an amp that lets you listen to music and appreciate how it’s been recorded. You’ll hear detail in familiar tunes that’s previously passed you by. It’s because hi-fi amps, like AXA25, are designed to take a signal from a source (like a CD player), amplify it and then output it to your choice of speakers.
Setting the Tone
With separate bass and treble controls, you can fine-tune AXA25’s sound to suit your taste, speakers, and the dynamics of smaller sized rooms. The centrally located volume dial, gives you finger-tip control over the 25 watts per channel of power at your disposal.
Wired for Sound
AXA25 has no less than 4 pairs of RCA inputs, a pair of recording outputs and a rear USB socket for technical upgrades. While hi-fi quality speaker binding posts (connectors) mean that thick cable connects securely for an authentic sound – you can even use banana plugs, should you wish.
Designed for Life
As with the rest of the AX Series, AXA25 shares our house-style of Lunar Grey minimalist fascia, black steel cabinet and ‘floating’ base. This timeless look allows for an upgrade path through our range. A slim build, in the classic 430mm hi-fi width, also means that AXA25 can easily slot into a much-loved system.
Cambridge Audio AXA25 Integrated Amplifier + AXC25 CD Player Axa_2510
AXC25
CD Player
  • Gapless Playback – ideal for classical pieces, live albums & DJ mixes
  • High-Quality Wolfson DAC – ensures the digital information from the disc is retrieved accurately
  • Slim elegant design – classic hi-fi design, floating effect wedge front foot, lunar grey finish
  • Digital display – classy white LED, clear visible information
CD Sound Comes First
AXC25 is an elegant, gapless playback CD player featuring a high quality digital to analogue converter (DAC). The integrated Wolfson DAC helps accurately retrieve digital information from your discs, to be output to your chosen amplifier – helping to breathe new life into your CD collection. The slim, standard hi-fi component width, player will slip unobtrusively into an existing setup.
Spinning Songs
You’ve spent years collecting CDs, so why wouldn’t you want to play them for many more years to come? AXC25 is a stylish slim CD player that will work with any amplifier or system.
Complete Control
AXC25 comes with a remote control, so you can choose exactly what to listen to. Compatibility of AX Series remotes means that you only need one device handy for key commands. Alternatively, you can use the controls on the front of AXC25 to skip tracks and so on.
Designed for Life
As with the rest of the AX Series, AXC25 shares our house-style of Lunar Grey minimalist fascia, black steel cabinet and ‘floating’ base. This timeless look allows for an upgrade path through our range. A slim build, in the classic 430mm hi-fi width, also means that AXC25 can easily slot, and breathe new life, into a much-loved system.
Cambridge Audio AXA25 Integrated Amplifier + AXC25 CD Player Axc_2510
012-2732555 Hew
016-3098668 John
017-2349074 Rick
012-2536225 Peter
012-2309169 Chris
MONDAY - 10AM-6PM
TUESDAY - 10AM-6PM
THURSDAY - 10AM-6PM
FRIDAY - 10AM-6PM
SATURDAY - 10AM-6PM
Cambridge Audio AXA25 Integrated Amplifier + AXC25 CD Player Trade
POWER OUTPUT    25 Watts (into 8 Ohms)
THD (UNWEIGHTED)    <0.015% @ 1kHz, 80% of rated power <0.15% 20Hz – 20kHz, 80% of rated power <0.1% 20Hz – 20kHz @ 10W
FREQUENCY RESPONSE (-3DB)    (-3dB) 10Hz - 30kHz
S/N RATIO (REF 1W)    >82dB (unweighted)
INPUT IMPEDANCES    32k ohms
POWER AMP DAMPING FACTOR    > 100
MAX. POWER CONSUMPTION    180W
BASS/TREBLE CONTROLS    Shelving, ultimate boost/cut +/- 5.5dB @ 20Hz and 20kHz
STANDBY POWER CONSUMPTION    <0.5W
INPUTS    4x RCA, 1 x 3.5mm Aux input (front panel)
OUTPUTS    Speakers, Rec Out, USB 5V power
DIMENSIONS (HXWXD)    83 x 430 x 340mm (3.3 x 16.9 x 13.4”)
WEIGHT    5.1kg (11.2lbs)
Cambridge Audio AXC25
THD @ 1KHZ -10DBFS    <0.015%
D/A CONVERTOR    Wolfson Microelectronics WM8524
GAPLESS PLAYBACK    Yes
FILTER    2 -pole Butterworth filter
FREQUENCY RESPONSE (+/-0.4DB)    20Hz - 20kHz
THD @ 1KHZ 0DBFS    <0.006%
S/N RATIO, A WEIGHTED    >93dB
CROSSTALK @1KHZ    <-95dB
CROSSTALK @20KHZ    <-95dB
OUTPUT IMPEDANCE    <50 ohms
MAXIMUM POWER CONSUMPTION    15W
DIMENSIONS    75 x 430 x 305mm (3.0 x 16.9 x 12.2”)
WEIGHT    4.3kg (9.5lbs)
Number of posts : 1323
