Meridian 551 Integrated Amplifier with Remote & MM Phono (Used)SOLD
Item: Meridian 551 Integrated Amplifier with Remote, power cord and manual.
This integrated sounds fantastic and has a moving magnet phono stage. It even has a built-in headphone amp at the back! Have a speaker on/off facility which allows you to enjoy music without disturbing others.
Condition: 8.5/10. In excellent condition, no scratches or dents.
Some info:
Description :
The Meridian 551 Integrated Amplifier uses a dual-mono construction similar to the 556 and 557 Stereo Power Amplifiers but includes a high-quality preamplifier similar to the 501. The preamplifier section provides six audio inputs, each of which can be individually adjusted for sensitivity, and identified on the four-character alphanumeric display. A very high quality MC or MM phono stage is available is optional for the dedicated LP input. The power amplifier section uses a unique feedback topology and precision local error correction system. It is designed and constructed in dual mono format, including a massive twin wound toroidal transformer.
Specifications :
Distortion.........................................Less than 0.05%
Signal/Noise.....................................Less than ·0dB for high-level analogue inputs.
.....................................Less than ·0dB for MM input.
.....................................Less than ·0dB for MC input.
MM option........................................Sensitivity adjustable 0.5 ·3mV for 5cm/s @ 1kHz.
........................................Overload point 47mV @ 1kHz.
........................................Cartridge load 47k Ohms 100pF.
MC option........................................Sensitivity adjustable 38 ·210?V for 5cm/s @ 1kHz.
........................................Cartridge load 220 Ohms 10nF.
Inputs..............................................5 phono inputs, sensitivity adjustable 27 ·150mV. Input impedance 20k.
Outputs...........................................2 outputs 55W per channel into 8 Ohms, 80W per channel into 4 ohms
............................................Volume control 99 steps of 1dB
Tape output......................................1.5V
Headphone......................................2V maximum output.
Comms...........................................Two 5-pin 240 - DIN sockets, RS232 interface.
Construction....................................Black textured enamel and glass finish.
....................................Side heatsinks from black painted aluminium.
Dimensions(w x d x h)..................... 321mm , 332mm , 88mm
Weight............................................10 kg (20lbs)
Controls..........................................Front-panel controls for Source, Copy, Spkrs,
..........................................Mute, Display, Volume up/down, Off.
Front Display...................................4-character dot matrix LED display.
http://www.tnt-audio.com/ampli/meridian551_e.html
http://www.meridian-audio.info/public/551%5B77%5D.pdf
http://www.meridian-audio.info/public/551_review%5B392%5D.pdf
http://www.audioreview.com/cat/amplification/integrated-amplifiers/meridian/551/PRD_115962_2717crx.aspx
Price: SOLD. Can also swap with your equipments.
Contact: Raymond 012-3816611
See my other amplifiers at : www.mudah.my/hifi-junction
Thank you.
Some info:
Description :
Specifications :
Thank you.
Last edited by raymond88 on Wed Jan 05, 2011 4:31 pm; edited 1 time in total (Reason for editing : SOLD)
» Meridian 551 Integrated Amplifier with Remote & MM Phono (Used)SOLD
» Arcam Alpha 6 British Stereo Integrated Amplifier With Phono and Remote (Sold)
» Nakamichi IA-2 Stereo Integrated Amplifier with Remote Phono MM MC
» [SOLD] Meridian 551 Integrated Amp with phono card (used)
» Meridian 551 Integrated Amplifier (Used) SOLD
