Help Needed
Page 1 of 1 • Share •
Help Needed
New to the forum so... greetings to all.
I have limited knowledge of audio matters and would welcome a bit of help/advice. I have a pretty basic set-up with Marrantz 1501 receiver coupled with Mordaunt Short Alumni 3.1 speaker system. Maybe I was wrongly advised in buying but I am a little disappointed with the sound I am getting - a bit too warm/mellow/bassy. I find out now that apparently if I want a brighter/sharper sound, I should have chosen a different receiver (Onkyo maybe) and also speakers other than my particular Mordaunts. Maybe later I will look to change something in my equipment but in the meantime I am thinking that perhaps my system could be better set up and in this respect is it possible that there is a knowledgeable member located in Kuching that could advise.
manukes- New Member
Number of posts: 5
Registration date: 2011-04-13
Re: Help Needed
Manukes,
Not trying to be an expert here, but base on your description; it sound like you are talking about music reproduction here. If yes, you have got a Ht setup that doesnt do well on music at all.
IMO, you need 15~20k on a decent HT setup that can play admirably on both Music and movie. That's only on the equipment count. You need know-how to make it really sing.
Mean time, I believe you would have 5 speakers and 1 Sub? Oh man, a lot of stuff to take care of. And it produces polluting noise if you dont have space/auxillaries for them to sing.
Suggestions: Things you can do other than relying on the evil Sound processor.. put your speaker on proper stand, fill with sand or lead to 70% full. Make sure it is spike to floor as well.
- Pull your speaker away from rear wall.
- Sit your receiver on cone or metal footer. spiky type.
- Other tweak will be including changing cables/Interconnect.
You can try what has been suggested in this link as well.
http://www.gcaudio.com/resources/howtos/tuningtips.html
Bear in mind, you may not hear anything on some of the tweaks suggested. Not because it is BullShit, most likely your system isnt resolving enough.
If you ask me, I will sell off the whole setup and get to Hi Fi stereo. Because it is cheaper and easier to setup decent sound than HT.
Number of posts: 425
Registration date: 2009-02-03
Re: Help Needed
Many thanks for very helpful response. I have 3 speakers and sub and the 3 speakers are bookshelf type (Mordaunt S. Alumni 2's and an Alumni 5 Centre. All sitting on cabinet. Might have misled a little by over-emphasising music preference which actually is nothing more serious that listening to Music DVD's (Eagles/Clapton/Taylor et al) and Films so thought that reasonal HT set up would be OK.
I am hoping to get someone to have a listen to it, then I may well pick a couple of my good track music DVDs and have a little tour around to see if I can listen to some alternatives. Then maybe I could sell of my gear which, though not off the top shelf, is OK, and I might find someone who wants a 'swop' - who knows. Main thing is I think right now is to see if my system can be improved by tweaking, so.... just hoping.
manukes- New Member
Number of posts: 5
Re: Help Needed
Out topic: What does it mean when the post is highlited in blue ? A warning ?
Wikin- Frequent Contributor
Number of posts: 276
Registration date: 2009-03-05
Source(s): PC Audio
Re: Help Needed
Actually I often wonder why it happens as well. Could be a bug. I don't see any functions on my moderator dashboard which allows me to change the background colour of a post. Or else, I'd probably end up changing most of the regular's posts - ppl like the eagle, MF, SJ, and gang - into blue colour because somehow we always end up talking cock !!
WongKN- Moderator
Number of posts: 1774
Registration date: 2009-01-20
Re: Help Needed
Maybe then you should have a button to stamp the avatar of frequent contributors with a cock... as in a 'chicken symbol' of approved cock talkers
Source(s): PC Audio
Re: Help Needed
That's a good idea. I wonder if the admin can be persuaded to check if this function is available. I am sure all of the regulars will then have the chicken as their avatar !! I will reserve especially big ones for SJ and MF !!
WongKN- Moderator
Re: Help Needed
Hello Uncle Manukes, whatever you do, do not buy and use snake oil. Being a wild life conservation enthusiast myself, I am most abhorred by the wanton destruction of snakes for their oil by the audiophile industry.
Yours, when the buying stops, the killings will stop too, moderneagle
moderneagle- Regular
Number of posts: 68
Registration date: 2011-01-30
Re: Help Needed
Hmmm.... snake oil from snakes. Now you guys know why if I were to have the function, I will make sure this eagle fellow gets the biggest chicken of all as his avatar !!
WongKN- Moderator
Re: Help Needed
moderneagle wrote:Hello Uncle Manukes, whatever you do, do not buy and use snake oil. Being a wild life conservation enthusiast myself, I am most abhorred by the wanton destruction of snakes for their oil by the audiophile industry.
manukes- New Member
Number of posts: 5
Re: Help Needed
Hi manukes, are you really 79 years old?
The reason for asking is probably at your age, there is limited frequency that you can hear. No pun intended ya. I guess you need to audition very thoroughly before you part any of your money be it HT or Hifi.
samn- Frequent Contributor
Number of posts: 110
Registration date: 2009-02-15
Re: Help Needed
samn wrote:Hi manukes, are you really 79 years old?![]()
The age is correct and you could be right about the frequency limitations. Certainly low frequency sounds could be a problem so maybe I need to check out something that will give more brighter sound...... as I said previously.
manukes- New Member
Number of posts: 5
Re: Help Needed
Damn... I must be thinking blue while replying that day
Anyway, I did add a link in the reply, wonder is that the triggle that make it turn blue..?
Re: Help Needed
Being a Manu red the worst scenario for me is having blue on my screen. Hope this is not an omen for tomorrows FACup Semi Final
manukes- New Member
Number of posts: 5
Similar topics» Member Ideas Needed
» Voice actress needed for an utau ~updated~
» Poetry Needed!
» Lump Charcoal Needed?
» Beta reader needed...
» Poetry Needed!
» Acoustic Preference Gracioso 1.0 Ex-Demo from manufacturer direct
» XLO thx certify speaker cable
» HI5LOFT brings back Xindak!
» NAD C326BEE Amp (Used)
» Copper color PENNY V power cord
» SQUARECIRCLES - Immediately Seek Attention
» SEAS Excel woofer
» Musical Fidelity F22 (used)
